cisco isdn router 26xx series problem with routing to another cisco router
Apr 07, 2005 2 Replies
Hello, we got ve' got a short problem with a router. this router shut make a dialup connection to another router. the dialin connection works fine and there is no problem. this router with the address 10.10.18.254 shut make a connection to the remote router with the ip 10.40.1.254 . when we send a ping to the 10.40.1.100 then is there no activity, but we can't see if the router dials or not. and so we not able to detect the failure. any Ideas ????
and here is the config file:
Current configuration : 1835 bytes ! version 12.3 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Router2 ! boot-start-marker boot-end-marker ! no logging console enable password 7 1415151F59162E33 ! username password username password username password username password username password mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no aaa new-model ip subnet-zero ip cef ! ! ! no ip domain lookup no ftp-server write-enable isdn switch-type basic-net3 ! ! ! ! interface BRI0 no ip address encapsulation ppp dialer rotary-group 1 dialer-group 1 isdn switch-type basic-net3 no cdp enable ! interface FastEthernet0 ip address 10.10.18.254 255.255.255.0 speed auto no keepalive ! interface Dialer1 ip address 192.168.1.105 255.255.255.0 encapsulation ppp no ip split-horizon dialer in-band dialer map snapshot 1 name Router1 broadcast dialer map ip 192.168.1.101 name Router1 broadcast 0123456789 dialer hold-queue 10 dialer-group 1 peer default ip address pool Router2-Group-1 snapshot client 15 360 suppress-statechange-update dialer no cdp enable ppp authentication chap ! router rip version 2 passive-interface Dialer1 network 10.0.0.0 network 192.168.1.0 no auto-summary ! ip local pool Router2-Group-1 10.10.18.200 10.10.18.201 ip classless ip route 10.40.1.0 255.255.255.0 192.168.1.101 ip http server ! logging trap debugging logging 10.10.18.100 dialer-list 1 protocol ip permit snmp-server community public RO snmp-server enable traps tty ! line con 0 exec-timeout 0 0 password login line aux 0 line vty 0 4 password login ! ! end
To make this dial you need a route to point to Dialer1 not the network.
config terminal no ip route 10.40.1.0 255.255.255.0 192.168.1.101 ip route 10.40.1.0 255.255.255.0 dialer1 end
You can debug this with the following commands terminal monitor debug isdn q931 if the router dials or not. and so we not able to detect the failure. any
ahh thanks for the answer. the problem is fixed and all works fine, it was a wrong prefix in the internal number. that means the number for the dialer was wrong. can you tell me how can i use the debug capabilities on the router. we got a syslog daemon on a machine in the subnet, and you can see the section trap debugging in the config file. when i use your comamnds in a telnet session in the config mode, where can i see the messages ? in the syslog daemon ? i think so, but now we can see the dialout-actions in the syslog daemnon. the day before there was no log about a dialout action.
greetings Randolf Balasus
