Boot Problem: 6509 with sup 720
Nov 27, 2006 4 Replies
Jump to replies (4)
Boot Problem: 6509 with sup 720 open original image
I have a 6509 with a sup 720 and when I boot, it goes into rommon. There is an image in flash which I can boot into, enterting the boot command from rommon. When I restart instead of booting to the image it goes into rommon. What do I need to change so it will boot directly into flash?
Perhaps you should investigate the status of your configuration register. Specifically:
Best regards,
-Z
dnuckle wrote:
in your configuration add:
boot system flash XXXXX:imagename.bin
XXX is the device that holds the image
example
boot system flash bootflash:sup720abc123.bin or boot system flash disk0:sup720abc123.bin or boot system flash slot0:sup720abc.123.bin
With the 720 the syntax is the following:
boot system flash sup-bootflash:sup720abc123.bin
