AP 1200
Oct 27, 2006 7 Replies
Jump to replies (7)
AP 1200 open original image
Hi guys, I have an Aironet 1200 that keeps reloading, I have tried the escape button to go to the rommon, and tried as well to recover the image through the Mode button, both are not working. I can not access both the CLI and the web page due to the frequent reload. I might have done something wrong with the image name for downloading it, where the Aironet configuration Guide mentions that the image should have the following format :
c1200-k9w7-tar.122-15.JA.tar
while what I get after upload is:
c1200-k9w7-mx.122-13.JA4.tar
So I changed the mx into tar desperately, and still it could not find the image after the Mode button recovery.
  1. Below you will find how it keeps reloading,
Ethernet port 0 initialized: link is up Loading "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4"...########### ################################################################################ ################################################################################ ################################################################################ ################################################################
File "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4" uncompressed and installed, entry point: 0x3000 executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.2(13)JA4, EARLY DEPLOYMENT RE LEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2004 by cisco Systems, Inc. Compiled Fri 16-Apr-04 12:22 by cmong Image text-base: 0x00003000, data-base: 0x0053CF74
Initializing flashfs...
flashfs[1]: 145 files, 6 directories flashfs[1]: 0 orphaned files, 0 orphaned directories flashfs[1]: Total bytes: 7741440 flashfs[1]: Bytes used: 7450624 flashfs[1]: Bytes available: 290816 flashfs[1]: flashfs fsck took 5 seconds. flashfs[1]: Initialization complete....done Initializing flashfs. Xmodem file system is available. flashfs[0]: 145 files, 6 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 7741440 flashfs[0]: Bytes used: 7450624 flashfs[0]: Bytes available: 290816 flashfs[0]: flashfs fsck took 26 seconds. Reading cookie from flash parameter block...done. Base ethernet MAC Address: 00:11:bb:bc:5a:94 Initializing ethernet port 0... Reset ethernet port 0... Reset done! ethernet link up, 100 mbs, full-duplex Ethernet port 0 initialized: link is up Loading "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4"...########### ################################################################################ ################################################################################ ################################################################################ ################################################################
  1. The Mode button.
button is pressed, wait for button to be released... button pressed for 47 seconds process_config_recovery: set IP address and config to default 10.0.0.1 process_config_recovery: image recovery image_recovery: Download default IOS tar image tftp://255.255.255.255/c1200-k9w7
-tar.default
examining image...tftp://255.255.255.255/c1200-k9w7-tar.default: no such file or directory
ERROR: Failed to open archive file tftp://255.255.255.255/c1200-k9w7-tar.default download takes about 0 seconds Loading "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4"...##########
And the TCP/IP setting for the TFTP are correct for sure.
To recover this AP1200, I would do this:
  1. Get an AP1200 image from CCO; use one of the following IOS versions: 12.3(7)JA4 12.3(8)JA2 12.3(8)JEA
  1. Find a computer that you can play with, and put a known good TFTP server on it. I like the current Solarwinds server; if you have your own favorite, so much the better.
  2. Put the new AP1200 image into the TFTP server's root direction; rename it to "c1200-k9w7-tar.default".
  1. Address this computer's LAN adapter with 10.0.0.2.
  2. Put this computer and the AP1200 on the same LAN.
  1. Perform the mode button recovery procedure.
If you still don't get things working as desired, go here for further instructions:
Aaron
Hi, i did try it, and i did it twice, where the image got downloaded on the AP and extracted, but i still have the same problem, the AP keeps reloading. I do not want to rule it as a hardware failure yet.
Hi, i did try that, and i tried it twice, the image did actually download and got extracted but i had the same problem, it kept on reloading. I do not want to rule it as a hardware failure yet.
Andy, After you recover the AP using the mode button you MUST tftp a new image to the box. The mode image load is to only recover the box and allow you to put the real image on it.
Hi Brian, the problem is that i can not acces the AP neither through the CLI, nor the HTTP to download any image, so i used the MODE button to download an image i have from another AP (tar file), and still the same problem it is not booting even to the rommon (ap:), i tried the escape key as well to go to the rommon and it is not working. Simply It keeps reloading, appreciate ur help.
Are you re-naming the image to the required name? Are you setting the IP on your PC to the required? Is the TFTP server on the local PC running? Is the TFTP server showing the image as being downloaded?
Please make sure you quote the thread as you reply, it makes it very difficult to follow the thread and give you the appropriate advise.
