Aironet 1200
Dec 10, 2006 1 Replies
Hi guys, i am having this log from one of the AP, i am using the same image on other APs without any problems. i researched this log and the recommendations varied between none and downgrading because of a bug, like i said i am using the same image on other APs. thank you for your help.
Delay after HW reset
Press RETURN to get started!
.You must specify at least one rate ...
*Mar 1 00:00:04.018: soap_pci_subsys_init: slot 3 found radio
Mar 1 00:00:11.199: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed - cmd busy
*Mar 1 00:00:11.199: -Traceback= 3A86E8 3A2C80 3A6F88 3A8014 3AC8D0
11B0E8 11B1 A0 38BF8 38E00 124DDC
Mar 1 00:00:13.295: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:14.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern et0, changed state to up .Mar 1 00:00:32.299: %SYS ap>
ap>
ap>
ap>
ap>-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.2(13)JA4, EARLY DEPLOYMENT RE LEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2004 by cisco Systems, Inc. Compiled Fri 16-Apr-04 12:22 by cmong
*Mar 1 00:00:32.299: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a c old start
Mar 1 00:00:32.402: %DOT11-2-RADIO_HW_RESET: Radio subsystem is under going ha rdware reset to rec.over from problem
*Mar 1 00:00:32.405: soap_pci_reconfig_radio: no radio on slot 3
Mar 1 00:00:33.393: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan ged state to up
*Mar 1 00:00:35.432: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Do t11Radio0, changed state to down.. ap>
ap>.done en Password:
*Mar 1 00:00:42.434: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0, loading the radio firmware (flash:/c1200-k9w7-mx.122-13.JA4/5100.img)
*Mar 1 00:00:43.493: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down ap#s
Mar 1 00:01:16.921: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed - cmd busy
*Mar 1 00:01:16.921: -Traceback= 3A86E8 3A2C80 3A6F88 3A8014 3ABC10
124DDCho
Mar 1 00:01:16.923: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0, loading the radio firmware (flash:/c1200-k9w7-mx.122-13.JA4/5100.i
Andy
How much RAM have you got in your APs
I had a similar problem with a batch of 1200 AP's I had. When I came to upgrade the IOS some would upgrade and some wouldn't. I ended up replacing the RAM in all the units to ensure the latest IOS would work on the all units
Steve
