6509 Boots to Rommon
Oct 12, 2006 6 Replies
Jump to replies (6)
Gang, I have a 6509 IOS native that boots into rommon after we cycle it.
If I type "Boot" at the rommon prompt, everything comes up fine. Show Boot shows: BOOT variable = CONFIG_FILE variable = BOOTLDR variable = bootflash:c6msfc3-psv-mz.122-17d.SXB11.bin Configuration register is 0x102
Standby is up Standby has 458720K/65536K bytes of memory.
Standby BOOT variable = Standby CONFIG_FILE variable = Standby BOOTLDR variable = bootflash:c6msfc3-psv-mz.122-17d.SXB11.bin Standby Configuration register is 0x102
This started happening after I converted from CAT OS to IOS Dir sup-bootflash shows: s72033-jk9s-mz.122-18.SXD7a.bin
Any help would be great.
You have your boot varible set to boot an invalid image. "BOOTLDR variable = bootflash:c6msfc3-psv-mz.122-17d.SXB11.bin"
The image in your flash is: "s72033-jk9s-mz.122-18.SXD7a.bin"
At the rommon prompt type: boot:c6msfc3-psv-mz.122-17d.SXB11.bin
After the system comes up correct your bootstring in your config
Ok, Do I have the wrong images in the wrong spot?
In Dir bootflash: I see c6msfc3-psv-mz.122-17d.SXB11.bin
In Dir SUP-Bootflash I see s72033-jk9s-mz.122-18.SXD7a.bin
Do I have those images in the correct place? and my bootldr should be c6msfc3-psv-mz.122-17x.SX11.bin?
When > wrote in
messagenews: snipped-for-privacy@c28g2000cwb.googlegroups.com...
text -- Show quoted text -
no one can answer that except you....what image is your prefered boot image?
If you are sure thats the boot image you want.....
clear boot system flash bootflash:c6msfc3-psv-mz.122-17d.SXB11.bin boot system flash sup-bootflash:s72033-jk9s-mz.122-18.SXD7a.bin
sho ver will verify
