S.O.S
Dec 07, 2006 3 Replies
Jump to replies (3)
Hi guys, I have a 4510R with SE V, and the standby SE is disabled after an image upgrade, is there a way for me to enable it manually?
CORE_MAN_01#sh module Chassis Type : WS-C4510R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
---+-----+--------------------------------------+------------------+----------- 1 2 1000BaseX (GBIC) Supervisor(active) WS-X4516 JAB081808GU 2 Standby Supervisor 3 6 1000BaseX (GBIC) WS-X4306-GB JAE0814AD2V 4 6 1000BaseX (GBIC) WS-X4306-GB JAE0814B2JX 5 6 1000BaseX (GBIC) WS-X4306-GB JAE0815C8JX 6 48 10/100/1000BaseTX (RJ45) WS-X4548-GB-RJ45 JAE0814AV8S
M MAC addresses Hw Fw Sw Status
--+--------------------------------+---+------------+----------------+--------- 1 000f.902a.4940 to 000f.902a.4941 1.0 12.1(20r)EW1 12.2(18)EW, EARL Ok 2 Unknown Unknown Unknown Other 3 000b.5f41.3532 to 000b.5f41.3537 2.2 Ok 4 000b.5f3c.e81e to 000b.5f3c.e823 2.2 Ok 5 0008.e366.b5ae to 0008.e366.b5b3 2.2 Ok 6 000f.8fc2.1bf0 to 000f.8fc2.1c1f 1.0 Ok
CORE_MAN_01#sho CORE_MAN_01#show redu CORE_MAN_01#show redundancy sta CORE_MAN_01#show redundancy states my state = 13 -ACTIVE peer state = 1 -DISABLED Mode = Simplex Unit = Primary Unit ID = 1
Redundancy Mode (Operational) = RPR Redundancy Mode (Configured) = RPR Split Mode = Disabled Manual Swact = Disabled Reason: Simplex mode Communications = Down Reason: Simplex mode
client count = 5 client_notification_TMR = 60000 milliseconds keep_alive TMR = 9000 milliseconds keep_alive count = 0 keep_alive threshold = 18 RF debug mask = 0x0
Here is something that I saw recently:-
Slot 1 sup had a new image put on its bootflash.
"boot system flash .... " command issued to configure new image to boot, "no boot system flash....." command issued to stop old image booting.
Force reboot of both SEs.
OOPS!
Thing was, no image corresponding to boot system flash command exists on standbybootflash:.
So second SE wont boot.
The fix is to manually boot second SE from Console (serial cable), there is no other way.
Ideally put correct image on flash card in slot0: and
rommon>boot slot0:c4500-is-mz-12.2.xxx.bin
Then it comes up.
You can also boot from tftp.
You need to read the docs. It is a bit weird but as long as you have console access and can either put an image in slot0 or can connect the "management port" and use tftp then it is easy enough to recover.
Thx, i recovered it just after i posted the message, i really appreciate ur reply. But i have the following problem with the boot variable, and i am trying to remove all these boot system flash command, i can not do so with the no boot system flash:
CORE_MAN_01#show bootvar BOOT variable = bootflash:/cat4000-i9s-mz.122-18.EW.bin,1;bootflash:cat4000-i9s-mz.122-18.EW.bin,1;bootflash:cat4000-i5k91s-mz.122-25.EWA7.bin,1;bootflash:/bootflash:/cat4000-i9s-mz.122-18.EW.bin,1 CONFIG_FILE variable does not exist BOOTLDR variable does not exist Configuration register is 0x2101
Standby BOOT variable = bootflash:/cat4000-i9s-mz.122-18.EW.bin,1;bootflash:cat4000-i9s-mz.122-18.EW.bin,1;bootflash:cat4000-i5k91s-mz.122-25.EWA7.bin,1;bootflash:/bootflash:/cat4000-i9s-mz.122-18.EW.bin,1 Standby CONFIG_FILE variable does not exist Standby BOOTLDR variable does not exist Standby Configuration register is 0x2101
snipped-for-privacy@hotmail.co.uk wrote:
thx problem solved.
