3600 boots always in rommon mode
Jul 07, 2006 8 Replies
Jump to replies (8)
Hello folks!
I upgrade my 3600 image (to 12.3(17b)) and now the router enters always in rommon mode after a reload command or power off-on.
I've got 2 solutions to boots up ok:
1) If I write "rommon> boot (+ Enter)" using Hyperterminal the router starts up OK, but 'show version' shows 'configuration register 0x0' (doesn't keep the register value I order it before reload)
2) Other solution to boots the image: rommon1>confreg boot: rom monitor console speed: 9600 . . rommon1> confreg 0x2102 rommon1> reset
And the router boots up OK. Now I write the next:
router# show ver . . Configuration register is 0x2102
router# sh runn | include boot boot-start-marker boot system flash c3620-is-mz.123-17b.bin boot-end-marker
router# dir flash: 1 -rw- 15789184 3620-is-mz.123-17b.bin
line con 0 is set up at speed 9600
But if I reload , the router enters int rommon mode again.
Any ideas? Do I have to setup anything else in rommon? Any misconfiguration?
Thanks, Charles.
The names do NOT match:
The filename in flash does not start with "c"
thanks Merv, sorry, but it was a problem with 'cut&paste':
router#dir flash: Directory of flash:/
1 -rw- 15789184 c3620-is-mz.123-17b.bin
the names MATCH perfectly. Any ideas?
Thanks.
Just a shot in the dark.
Try changing the confreg from IOS when you get it IOS up.
adsl#sh ver ... Configuration register is 0x2102 ......
adsl# adsl# adsl#conf t Enter configuration commands, one per line. End with CNTL/Z. tnatsis-adsl(config)#config-register 0x1234 tnatsis-adsl(config)#^Z tnatsis-adsl#sh ver .... Configuration register is 0x2102 (will be 0x214 at next reload) .... adsl#reload
I don't know what a confeg of 0x0 does, maybe that is not affecting anything.
Agreed. I've been bit by a 3845 that had a similar problem. Setting the config register from rommon did no good. I had to set in from the IOS (a couple times if memory serves) to fix my problem.
J
Try this:
boot system flash:c3620-is-mz.123-17b.bin
I got bit with the same thing on a 3700. Worked on that one.
If problem continues, remove the boot system command and the router will try to booo the first image in flash
Been reading 6500 documents. confreg 0x00 has a boot field of zero (last 3 bits) which will cause the device to remain in the ROM monitor.
Other reasons for remaining at ROM monitor include:- - Invalid software image - Corrupt config
So:- Boot router
conf t config-r 0x2102 end
wr
reload
There may be a variation between platforms in these regards and this is specifically for 6500, but worth a look.
