3640 latest 124-16 wont fit in flash
Aug 18, 2007 8 Replies
Jump to replies (8)
im trying to load the latest 3640 ios (c3640-jk9o3s-mz-124-16.bin), however with max 32mb flash i cant load it. it says not enough space on device. im currently running jk9o3s-mz-124-5a. on my linux box ls - l shows 34755788.
any ideas?
thanks
| im trying to load the latest 3640 ios (c3640-jk9o3s-mz-124-16.bin), | however with max 32mb flash i cant load it. it says not enough space | on device. im currently running jk9o3s-mz-124-5a. on my linux box ls - | l shows 34755788.
You can boot it by rcp (or ftp). I don't think tftp is practical unless big block support works. Note that whatever IOS image rommon uses as the helper to execute the rcp/ftp boot needs to be small enough for both itself and 12.4(13) to fit in memory. This obviously precludes using a recent jk9o3s image as the helper.
By default rommon uses the first flash image as the helper. You can change this by setting the BOOTLDR monitor variable. I stuck an old
12.0 IP-only image in flash to use as the helper and pointed BOOTLDR at it. I'm not sure there is room to have the last jk9o3s image that fit plus an image that can load 12.4(13); anybody know the smallest image that will work for the latter? Maybe with a PCMCIA flash card...
Note that configuring "boot system" statements from IOS does update the rommon BOOT variable as expected, but "boot bootstrap" statements do not update the BOOTLDR variable and there seems to be no "boot bootldr" even though it is mentioned in the documentation. Also, there is no "show bootvar" or "show bootenv" or such to see what the monitor thinks about the world from the IOS CLI.
Dan Lanciani ddl@danlan.*com
"Jay Franklin" ha scritto nel messaggio news: snipped-for-privacy@q3g2000prf.googlegroups.com...
Try erasing the flash with the "no-squeeze" option.
Regards, Gabriele
3640 supports a maximum flash memory size of 32 MB = 32,768,000 bytes.
The ENTERPRISE/FW/IDS PLUS IPSEC 3DES ( c3640-jk9o3s-mz-124-16.bin) image size of 34,755,788 bytes exceeds that amount.
It would seem that Cisco has posted an image on CCO that cannot be loaded onto a 3640.
If you have a support contract then ask the Cisco TAC to confirm.
There was a thread on this earlier in the month: "have a 3640 with 32M memory. I was trying to load : c3640-jk9s-mz.124-16.bin"
One tiny thing for Merv, I would have thought that
32M flash contained 32 * 1024 * 1024 and not 32 * 1024 * 1000?
Anyway the image won't fit and you will have to choose a different one, or boot from an alternative source.
Choose one with fewer features that jk9s.
12.3.23 Enterprise plus 3des is only 22M.
Finally note that there is some file system overhead and the image that will fit in a 32M flash is a bit less than
32M.
sh flash
shows the true free bytes.
In article , snipped-for-privacy@rogers.com (Merv) writes: | | | 3640 supports a maximum flash memory size of 32 MB = 32,768,000 | bytes. | | The ENTERPRISE/FW/IDS PLUS IPSEC 3DES ( c3640-jk9o3s-mz-124-16.bin) | image size of 34,755,788 bytes exceeds that amount. | | It would seem that Cisco has posted an image on CCO that cannot be | loaded onto a 3640.
Well, you can load it in the sense that you can rcp (or ftp) boot it; I tried the other day. I actually think it's kind of nice that they not stop releasing images just because the images got too big for flash, but then I'm not trying to use a 3640 for production. :)
thanks for all the responses. i suppose ill just boot it from ftp. i have a pcmcia card, but its only 20MB. afaik, the max pcmcia flash that the 3600 series supports is 20mb. is this correct?
thanks.
Jay
ps- it seems the latest 3620 enterprise/fw/ids ipsec 3des also doesnt fit into the max flash. just for the record.
In article , snipped-for-privacy@gmail.com (Jay Franklin) writes: | thanks for all the responses. i suppose ill just boot it from ftp. i | have a pcmcia card, but its only 20MB. afaik, the max pcmcia flash | that the 3600 series supports is 20mb. is this correct?
That's certainly what the documentation says; I'd be interested to find out if it is false...
| ps- it seems the latest 3620 enterprise/fw/ids ipsec 3des also doesnt | fit into the max flash. just for the record.
Which one is that? I thought that feature set (or at least the plus version) wasn't available for the 3620 beyond 12.2 with 12.2(46a) being the latest at under 16M.
Whoops. i meant the ip/fw/ids ipsec 3des w/o atm (c3620-ik9o3s6-mz.
123-23.bin).
yes, id also like to see if the 20mb pcmcia flash was the limit. id love to use a 40 or 64mb card with my 36x0 series.
thanks.
Jay
