Clear flow control counters 6513
Dec 06, 2006 4 Replies
Jump to replies (4)
Does anyone know how you clear the flow control counters displayed under the show flowcontrol command.
I am using a 6513 sup 720 IOS ver 12.2(18)SXF5
Many thanks
Nope
It used to work on our Sup2 with CatOS.
I have the same problem - is it a bug in software or is there another command? I have read the command reference and cant find anything in there either.
Does anyone know how to do this (apart from >reload!!)
on SUP720 with 12.2(18)SXF6 clear counters commands works fine
xxx#sh ver Cisco Internetwork Operating System Software IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version
12.2(18)SXF6, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2006 by cisco Systems, Inc. Compiled Mon 18-Sep-06 23:03 by tinhuang Image text-base: 0x40101040, data-base: 0x42D90000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1) BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version
xxx uptime is 5 days, 13 hours, 16 minutes Time since xxx switched to active is 5 days, 13 hours, 15 minutes System returned to ROM by reload at 07:26:32 EST Mon Nov 6 2006 (SP by reload) System restarted at 22:39:19 EST Fri Dec 1 2006 System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.SXF6.bin"
cisco WS-C6509 (R7000) processor (revision 2.0) with 458720K/65536K bytes of memory. Processor board ID SCA051000PW SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache Last reset from power-on SuperLAT software (copyright 1990 by Meridian Technology Corp). X.25 software, Version 3.0.0. Bridging software. TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface 48 FastEthernet/IEEE 802.3 interfaces 34 Gigabit Ethernet/IEEE 802.3 interfaces 10 Ten Gigabit Ethernet/IEEE 802.3 interfaces 1917K bytes of non-volatile configuration memory. 8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102
xxx#clear counters Clear "show interface" counters on all interfaces [confirm]
Did it clear all of your flow control Counters ie tx pause and rx pause from the
That is what I am trying to clear with the >Clear counters command it clears everything else just not the flowcontrol stats.
This is my sh ver:-
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-18.SXF5.bin"
cisco WS-C6513 (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory. Processor board ID SAL1019MLSU SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache Last reset from s/w reset SuperLAT software (copyright 1990 by Meridian Technology Corp). X.25 software, Version 3.0.0. Bridging software. TN3270 Emulation software.
64 Virtual Ethernet/IEEE 802.3 interfaces 234 Gigabit Ethernet/IEEE 802.3 interfaces 1917K bytes of non-volatile configuration memory. 8192K bytes of packet buffer memory.
