2621XM Problem (Probably Easily Resolved!)
Jun 18, 2006 3 Replies
Jump to replies (3)
2621XM Problem (Probably Easily Resolved!) open original image
Hi folks, I have a Cisco 2621XM router. My problem is that when I power it up, it goes through the initial loading routines ok, but when it comes to the point:
---------------- "router-name" con0 is now available
Press RETURN to get started.
I press RETURN and nothing happens, like it's frozen or something. Can anybody help me figure out how to get it to respond? I'm just about to go mad!
Thanks guys,
Danny
Hi Danny,
You may wish to investigate Cisco's Troubleshooting Router Hangs:
Hope this helps.
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
Does your terminal/cable work with another router? If not suspect cable, or settings. e.g. if your terminal was set to do handshaking I think that this would be the observered symptoms. In IOS operation it may be possible to set different Tx and Rx parameters. You could try going into Rom Monitor which always uses symmetric parameters. To do this press control C during boot. See "password recovery" on Cisco web site.
