2500 stuck in rxboot
Dec 11, 2006 2 Replies
Hi all,
I have a 2503 that is stuck in rxboot mode. I have tried to load a new ios from my tftp server but the router will not take any of the copy commands. I have also tried connecting another router and running a tftp server on it, but my broke router cannot find it.
Am i able to use the console cable to load an ios? I have done so previously, but it was on a 2600.
Any suggestions?
Many thanks
Max
Are you in rxboot or rommon? What is your prompt?
router(boot)> (or router(boot)# ) rommon 1>
which of the 3?
The first one is easiest (properly called rxboot). enable, 'copy tftp: flash:'
The other two require you to get to rxboot mode.
Here is the prompt after enable, and options for copy
------ router(boot)#copy ? flh-log
router(boot)#copy
It is not giving me the option to copy tftp etc.
Thanks
