2600 flash erased
Aug 01, 2006 2 Replies
2600 flash erased open original image
My cisco 2610 flash has been erased and it is unable to boot from ios. please tell me the way to re install the ios.
You may wish to investigate How to Download a Software Image to a Cisco
2600 via TFTP Using the tftpdnld ROMMON Command:
as well as Xmodem Console Download Procedure Using ROMmon:
and ROMmon Recovery for the Cisco 2600 Series Router and the VG200:
Hope this helps.
Brad Reese BradReese.Com - Cisco Power Supply Headquarters
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Jobs
Well, by erasing your flash, you obviously erased the ios-image as well.
To reinstall the image (which can be done from the bootloader) you have to connect to the console with a terminal-program.
Then you copy your ios-image (of which you have a backup hopefully) to a tftp-server and the bootloader can load it to flash from there (via tftp),
or
if you don't have a tftp-server, you can download the image to flash with the terminal-program (if the terminal-program is capable of doing x-modem, z-modem transfers).
Rainer
