IOS Upgrade through console in cisco 2500
Mar 19, 2005 7 Replies
Jump to replies (7)
You may wish to investigate the Cisco IOS Software Selector:
as well as Cisco IOS Upgrade Planner:
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center United Kingdom: 44-20-70784294 U=2ES. Toll Free: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558=20 Website:
bns,
What kind of info are you looking for here? How to upgrade the IOS? Or what IOS to upgrade to?
For basic info on how to do the upgrade see:
For info on what IOS to upgrade to see Brad's earlier post.
HTH,
-Richard
I want to upgrade IOS through console . How to do kindly advise bns
Howard is correct if you currently have a functional IOS. If not, then you'll have to load it through the console port.
Boot into rommon mode. Change the console rate to 115200 (otherwise it'll take a lot longer). You'll have to restart HyperTerm (or whatever program your using) to match the 115200 console rate. Transfer the file via HyperTerm using xmodem (it steps you through the process, use the ? for help in rommon mode). It may seem like it's not doing anything after it's done xferring but the checksum on the image xferred may take a while. (You'll see the hex numbers slowly count upwards). When it's done reload the router, providing it's a supported IOS for that model and you have sufficient flash and ram, it should be successful.
Good instructions for recent routers whose console ports support xmodem; however the 2500 is not one of them.
On the 2500, you'll have to load code via TFTP thru the Ethernet.
Aaron
