Hi, i have 2 netgear access point. Why i can use only netgear wireles card to connect with WEP?
Thanks for help. Syu
"Syucomm" hath wroth:
Use the Hex key instead of the ASCII key and non-Netgear wireless devices will work. However, I suggest you switch to WPA as WEP has some rather bad security problems.
Hi, i have tried but still not work...
On 13 Feb 2007 05:46:11 -0800, "Syucomm" wrote in :
Turn off _all_ security when troubleshooting! Ideally by resetting the wireless access point/router to hardware defaults and starting over. Only turn security on once you've got it working! And of course be sure to do so, preferably with WPA.
