Hello all,
I am having trouble getting Internet connectivity for my clients on a
876W Cisco. My setup is this:Wired/Wireless Clients --> Cisco 876W --> D-Link AP2200 --> D-Link AP2200 --> Cable Modem --> Internet
So, there are wired and wireless clients connected to the 876 router. Connectivity for the wired clients is ok, but the wireless clients can only get as far as their default gateway. I am posting the configuration of the 876, maybe somebody can spot something ?
Using 3022 out of 131072 bytes ! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname 876W ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical ! clock timezone PCTime 2 clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 4:00 no aaa new-model ip subnet-zero no ip source-route ip cef ! ! ip tcp synwait-time 10 no ip bootp server ip domain name yourdomain.com ip ssh time-out 60 ip ssh authentication-retries 2 no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface BRI0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown no cdp enable ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown no atm ilmi-keepalive dsl operating-mode auto ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface Dot11Radio0 no ip address ! ssid OFFICENET vlan 1 authentication open ! ssid ciscowep vlan 2 authentication open ! speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0 channel 2437 station-role root no cdp enable ! interface Dot11Radio0.2 encapsulation dot1Q 2 no cdp enable bridge-group 2 bridge-group 2 subscriber-loop-control bridge-group 2 spanning-disabled bridge-group 2 block-unknown-source no bridge-group 2 source-learning no bridge-group 2 unicast-flooding ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan2 no ip address bridge-group 2 bridge-group 2 spanning-disabled ! interface BVI1 ip address 192.168.1.1 255.255.255.0 ! interface BVI2 ip address 192.168.2.1 255.255.255.0 ! ip classless ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ! logging trap debugging no cdp run route-map ON_Route permit 10 match ip address 1 ! ! control-plane ! bridge 1 route ip bridge 2 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport preferred all transport output telnet line aux 0 login local transport preferred all transport output telnet line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end
Thanks in advance for all your help !
Naz
