876W Wireless
Nov 18, 2006 5 Replies
Jump to replies (5)
Hello
I'm trying to configure the wireless part of a cisco 876 without success. I can get the wireless to authenticate using wpa, but it will not get an IP address.
If possible i would like them to get an address from the DHCP pool
Here is my config if anyone can help me please
version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname router ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! no aaa new-model ! resource policy !
ip subnet-zero ip cef no ip dhcp use vrf connected ip dhcp excluded-address 192.168.3.1 ! ip dhcp pool office import all network 192.168.3.0 255.255.255.0 default-router 192.168.3.1 ! ! no ip domain lookup ip domain name yourdomain.com ! ! crypto pki ! ! ! bridge irb ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface ATM0 description $ES_WAN$ no ip address no ip route-cache cef no ip route-cache no atm ilmi-keepalive pvc 2/32 ubr 500 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface ATM0.1 point-to-point no ip route-cache ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Dot11Radio0 no ip address ip access-group 101 in ! encryption vlan 1 mode ciphers tkip ! encryption mode ciphers tkip ! ssid Office vlan 1 authentication open authentication key-management wpa guest-mode wpa-psk ascii 0 ******** ! speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 station-role root ! interface Dot11Radio0.1 description office open encapsulation dot1Q 1 native no snmp trap link-status no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$ ip address 192.168.3.1 255.255.255.0 ip verify unicast reverse-path ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 bridge-group 1 bridge-group 1 spanning-disabled hold-queue 32 in ! ! interface Dialer0 ip address negotiated ip verify unicast reverse-path ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap callin ppp chap hostname ***** ppp chap password 7 ************* ppp pap sent-username ****** password 7 ********* ppp ipcp dns request ppp ipcp mask request ppp ipcp address accept ! interface BVI1 ip address pool office ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 permanent ! ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ip nat inside source list 101 interface Dialer0 overload ! access-list 101 permit ip 192.168.3.0 0.0.0.255 any dialer-list 1 protocol ip permit
no cdp run ! control-plane ! !
end
VLAN 1 here is not what I have seen working.
I use this:-
! DHCP omitted but using range ! 10.1.37.0 255.255.255.0
bridge irb ! ! interface Dot11Radio0 no ip address ! encryption mode ciphers tkip ! ssid HR_ABC authentication open authentication key-management wpa wpa-psk ascii 7 12160B121
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 station-role root no dot11 extension aironet no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 no ip address ip tcp adjust-mss 1452 bridge-group 1 !
! interface BVI1 ip address 10.1.37.2 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! bridge 1 protocol ieee bridge 1 route ip
I recently tried to get two ssid's operating such that they could be on different VLANs and I failed. Ideas welcome.
Good luck.
I'm trying to do the same thing
Sorry Anybody,
did or didn't you get the bridge working? I have the same conf (authentication apart, I'm at the beginning) but it doesn't work (I've got a 871W)
maybe the above command makes the difference
As far as I know you can specify which VLAN a SSID is associated to using the command "vlan " within the ssid section
HTH Alex
The config I posted earlier works.
As I said I tried something like:-
vlan database vlan 2 exit
bridge irb ! ! interface Dot11Radio0 no ip address ! encryption mode ciphers tkip ! ssid HR_ABC authentication open authentication key-management wpa wpa-psk ascii 7 12160B121 vlan 1
ssid HR_DEF authentication open authentication key-management wpa wpa-psk ascii 7 xxxxxx vlan 2
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 station-role root no dot11 extension aironet no cdp enable ! interface Vlan1 no ip address ip tcp adjust-mss 1452 bridge-group 2
interface Vlan2 no ip address ip tcp adjust-mss 1452 bridge-group 2
bridge 2 protocol ieee bridge 2 route ip
This is from memory and may be faulty.
It did not work anyway. No IP communications, no DHCP. Wireless association was OK.
The same problem I faced.
Let me investigate
Alex.
snipped-for-privacy@hotmail.co.uk wrote:
The following (just on a test machine) works:
- - - - ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname W-router ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! ip cef ! no ip dhcp use vrf connected ! ip dhcp pool 10_10_10_0_24 network 10.10.10.0 255.255.255.0 default-router 10.10.10.254 ! ip dhcp pool 20_20_20_0_24 network 20.20.20.0 255.255.255.0 default-router 20.20.20.254 ! ip dhcp pool 30_30_30_0_24 network 30.30.30.0 255.255.255.0 default-router 30.30.30.254 ! bridge irb ! interface FastEthernet0 switchport trunk allowed vlan 1,10,20,30,40,1002-1005 switchport mode trunk ! interface FastEthernet1 switchport access vlan 10 ! interface FastEthernet2 switchport access vlan 20 ! interface FastEthernet3 switchport access vlan 30 ! interface FastEthernet4 no ip address shutdown duplex auto speed auto ! interface Dot11Radio0 no ip address ! ssid VLAN10 vlan 10 authentication open ! ssid VLAN20 vlan 20 authentication open guest-mode ! ssid VLAN30 vlan 30 authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0 station-role root ! interface Dot11Radio0.1 encapsulation dot1Q 10 bridge-group 10 bridge-group 10 subscriber-loop-control bridge-group 10 spanning-disabled bridge-group 10 block-unknown-source no bridge-group 10 source-learning no bridge-group 10 unicast-flooding ! interface Dot11Radio0.2 encapsulation dot1Q 20 bridge-group 20 bridge-group 20 subscriber-loop-control bridge-group 20 spanning-disabled bridge-group 20 block-unknown-source no bridge-group 20 source-learning no bridge-group 20 unicast-flooding ! interface Dot11Radio0.3 encapsulation dot1Q 30 bridge-group 30 bridge-group 30 subscriber-loop-control bridge-group 30 spanning-disabled bridge-group 30 block-unknown-source no bridge-group 30 source-learning no bridge-group 30 unicast-flooding ! interface Vlan1 no ip address ! interface Vlan10 no ip address bridge-group 10 ! interface Vlan20 no ip address bridge-group 20 ! interface Vlan30 no ip address bridge-group 30 ! interface Vlan40 ip address 40.40.40.1 255.255.255.252 ! interface BVI10 ip address 10.10.10.254 255.255.255.0 ! interface BVI20 ip address 20.20.20.254 255.255.255.0 ! interface BVI30 ip address 30.30.30.254 255.255.255.0 ! ! ! no ip http server no ip http secure-server ! ! ! ! ! control-plane ! bridge 10 protocol ieee bridge 10 subscriber-policy 1 bridge 10 route ip bridge 20 protocol ieee bridge 20 subscriber-policy 1 bridge 20 route ip bridge 30 protocol ieee bridge 30 subscriber-policy 1 bridge 30 route ip ! line con 0 no modem enable line aux 0 line vty 0 4 login ! scheduler max-task-time 5000 end
I think the problem is because you use VLAN 1. CAn you confirm? As You can see I used VLANs different from the default one (number 1)
Let us know.
HTH Alex.
