3600 RAM and Flash Uopgrade
I need to replace all Flash and RAM on a 3640 router and I know I will loose both the config and the IOS Image.
What are the procedures for this? I cannot seem to find anything on cisco.com although I am sure there must be some.
we have a PCMCIA card in the router so we can store the IOS and image locally.
Gary
Gary
Gary schrieb:
Hi, why don't you use a tftp-server for the backup ? copy flash tftp and copy start tftp
after changing flash and memory assign an ip-address and then copy tftp flash and copy tftp start.
bye christoph
Christoph Hanle
How will it boot without an IOS?
Will the bootstrap IOS be enough? Is that what you are saying?
Gary
Gary
Change the RAM, change the FLASH. You wont lose your config because thats in the NVRAM. It will boot off your PCMCIA card providing there is an IOS image on there. You can then copy that to FLASH or copy a new image to FLASH from a tftp server.
Cheers
Matt
Matty M
Copy flash:iosimagename slot0: ! moves flash to slot copy stratup-config slot0:config ! puts sonfig file on slot
Once the flash SIMMs are removed, system should boot from slot 0, if not you should be able to instruct the system to boot from slot0: from ROM monitor (boot slot0:)
Then just reverse
copy slot0:imagename flash copy slot0:config startup-config
Phillip Remaker
