ROUTE, VPN and DSL
Nov 15, 2004 2 Replies
Hi, I'd want to trough a DSL-router in a transparent way, so I can use two VPN machines.
Local situation: router DSL: USR SURECONNECT 9105 WAN: 82.xxx.xxx.242 (fixed ip) LAN: 192.168.1.1
VPN+Router: IPCOP WAN: 192.168.1.254 (RED interfaces) LAN: 192.168.130.254 (GREEN interfaces)
I'd want, but I'm not so able to do since now, that when public IP is pinged (82.xxx.xxx.242), the packet reach IPCOP machine, so everything from WAN should goes to IPCOP.
The route table of DSL router is: Destination Gateway Genmask Flags Metric Ref Use Iface
82.xxx.xxx.0 * 255.255.255.0 U 0 0
0 atm49
192.168.1.0 *
255.255.255.0 U 0 0
0 br0 default 82.xxx.xxx.254 0.0.0.0 UG 0 0
0 atm49
I have access to the route table of DSL-router; how can I setup this "simple" static route I need?
Thanks Gianluca
Not sure if I fully understand, but maybe you need a "net" route for
192.168.130.0/255.255.255.0 network using gateway 192.168.1.254 on br0
