Hi i have a old Samsung -ML1520 laser printer and i am trying to connect it to a...
J
Jeff Liebermann
Mark McIntyre hath wroth:
- Is it Cisco PAT or the industry convention of calling everything NAT?
- Is it a Layer 3 switch, or it is a router?
- What every happened to the brouter (bridge-router)?
- Is it a repeater, or an ethernet hub?
- When will MPLS (multi-protocol label switching) handle more than one protocol?
Linux is a "toy OS"? You realize that this might offend the righteous and bring the protesting horde to your doorstep? As a former member of the SCO contingent, I can assure you that insulting Linux is a very bad idea.
Also it's not "throw away". The politically correct term is "recycleable".
Anyway, I'll conceed the point, call it a "print server" and promise to be good, at least until marketing invents a new buzzword.
F
Frazer Jolly Goodfellow
John Navas wrote in news:KYyWf.40373$ snipped-for-privacy@bgtnsc04-news.ops.worldnet.att.net:
... compounded by crass product market differentiation BS through proprietary and pre-standards functionality: RangeMax, pre-N, MIMO etc. These are *consumer* products fercrissake!
Fortunately I'm able to help local non-tech users to acquire and install the right solution for their requirements - for a reasonable fee, of course :-)
These products are not industrial-strength, nor intended to be so, they are *very* good value for money and reliable enough for their target market. For example, in my own network my Linksys WRT54G runs continuously for longer than two months at a time without problem. When it begins to falter, a quick power-cycle restores it to normal service - no problem once you're used to it.
I expect it would last several minutes at a stretch running flat-out in a corporate network.
M
Mark McIntyre
Who mentioned Linux?
I'm scared... :-)
Yeah, right. :-)
Mark McIntyre
J
John Navas
d[POSTED TO alt.internet.wireless - REPLY ON USENET PLEASE]
Linux is the OS on some of your "throwaway consumer devices" (e.g., Linksys). Or didn't you know that? ;)
J
Jeff Liebermann
You proclaimed that the cheap consumer routers use a "toy OS" as in: "In the latter, routers are throwaway consumer devices running a toy OS ..." I'm sure you know that many consumer routers use Linux as their OS. Others are VxWorks, QNX, and a mess of Linux derivatives.
Walk carefully when you tread upon the sacred cow of a Linux product or wrath of the fanatical multitudes will be upon thee.
M
Mark McIntyre
Like I said, where did I mention Linux
So what?
ICGTW. FWIW I use linux extensively at work (RHEL3/4) and its a fine OS. I'd not describe it as a dedicated OS for running firewalls tho. Mark McIntyre
R
Rosco
Mark McIntyre cried out
You didn't directly, but of course the Linux people will pull it out of the convo somehow, dear god here it comes, i probably shouldn't have said that
M
Mark McIntyre
*shrug* LICGAF
And here's me building a PC and installing RH Fedora core to use as a mailserver and webserver, as a project with my son over Easter.
Mark McIntyre
Report Content
ASAP.
