adding wired router/print server into wireless network
Aug 24, 2005 1 Replies
I have 4 computers on my Linksys wireless network and I want to be able to share my printer wirelessly. I have a D-link wired router with built in print server. Is there any way I can hook the D-link router to the Linksys WRT54G, turn off DHCP, and just use it as a print server? If not does anyone know of a cheap solution for a print server? Thanks!
Aaron
"copytekk" wrote in news:1124854361.345913.14130 @g14g2000cwa.googlegroups.com:
Well, if it doesn't work for you you can get a Cables To Go print server it works like a champ. I got it for about $40 big ones at the time.
Long version
Short version
You can select from the drop down list to select by manufacture.
Duane :)
