upgrade questions
Jun 24, 2006 2 Replies
I'm considering upgrading my router/wireless components. I've got high-speed cable and two computers, one is a desktop and one is a laptop without internal wireless. Currently I'm running the laptop with a Linksys Instant wireless PCI Card (Version 3) and a Linksys BEFW11S4 Router. It is 2.4GHz and 802.11b. I've also using Vonage and once in awhile I have to reset the router, etc. for some reason. Not a huge deal but a bit of a pain. My main issue is that inside my own house (2400 sq. ft so it's not overly huge) I get very low signal strength on my laptop. I find that odd since my neighbors say they can see my network sometimes as much as 100 yards away. I'm wondering if I upgrade to a "g" router will I get much better reception and speed. The speed is not much of an issue right now but the signal strength is. Also, if I do upgrade the router will I have to upgrade the PCI card as well. If so any suggestions on the router and card or general setup? thanks, Drew
On Sat, 24 Jun 2006 14:23:31 -0400, "DP" wrote in :
Probably not, unless you go completely NIMO.
All you might need is a better antenna -- see wikis below.
To get better range, go with a better antenna, or with NIMO on both ends.
