Unstable wi-fi connection with D-Link DI-624 router and WPA-PSK
Feb 26, 2006 2 Replies
I have two wireless routers: SMC2804 and D-Link DI-624. I have configured both to use WPA-PSK encryption. Both of them have updated firmwares.
The SMC works fine with my two notebooks (HP NC4000 and Dell Latitude
610, both running Windows XP SP2).
However, I am facing a lot of problems with my D-Link... With my HP notebook, the connection seems to be unstable (the notebook connects to the network. After some seconds, it desconnects and then re-connects... and so on).
My Dell is unable to connect to the D-Link (I always get the "limited or no connectivity" error). The weird thing is: if I connect the Dell using a normal LAN connection, it works and, after a while, the wi-fi connection also works... (???)
I=B4ve discovered that both notebook work fine if I change the D-Link configuration to WEP.
What is going on? I=B4ve googled for similar problems and I found many people with the same problem, but I didn=B4t find any solution...
Thanks,
What kind of adapters are you using? D-Link routers are known for working best with D-Link adapters.
Both notebooks have native wi-fi adapters. I have tried a lot of different configurations (example: I disabled the Turbo Mode, the Enhanced Mode, etc), but the problem persisted. I can only use the D-Link router in the WEP configuration...
optikl escreveu:
