Problem with DHCP
Jan 17, 2005 1 Replies
Hi I have connected successfully to tiscali broadband with Speedtouch 580 ADSL router. Periodically the internet connection fails. The symptoms are as follows:
- Internet doesn't work
- WAN and DSL lights on the Speedtouch 580 are on
- The internet light is flashing (which apparently means internet in use, though when the system is working and not in use, there is a continuous light here)
- Diagnostics reveals that there is no connection to the DHCP (?)
- If I rerun the configuration CD a number of times and do several reboots of the 580 I can get the connection to work (sometimes the TCP/IP finds no machine, and then sometimes it does).
Anyone know how to fix this?
snipped-for-privacy@excite.com (grist2mill) wrote in news: snipped-for-privacy@posting.google.com:
You may just want to re-flash the router with the current version of the firmware the router is using to see if that corrects your problem.
Duane :)
