wireless newby
Jan 17, 2005 2 Replies
supplied to
The modem is required, its has to do some modulating and demodulating
hi I've just signed up to wanadoo ADSL. does anybody know if I have to connect the free broadband modem supplied to my D Link DI-624 802.11g / b Wireless Router of can I connect the router straight to the ADSL line - so skipping the modem thanks Chris
No, Your router doesnt have a ADSL Modem built in.
Indeed your modem from Wanadoo will be a USB modem. You will find that this wont connect to your router as your router has a WAN port for connecting an ethernet ADSL modem to it.
USB Modems (like the one you have) are designed to connect directly to your PC.
You probably would need a DSL-G604T to complete the setup.
See this link for how to connect up your kit.
I signed up with Wanadoo last October and I bought a Wireless Router with built in ADSL modem. The Wanadoo modem sits in the cupboard in case of emergencies.
HTH
Harry
