Netgear ME 102 pass word needed
Mar 24, 2005 11 Replies
Jump to replies (11)
I'm using an ME102, but it has been several years since I set it up. I believe that it came with a blank password by default. I'd try a hard reset of the device.
Again, I'm not really sure. Generally, devices are reset to factory default by holding in the reset button for approximately 15 seconds while applying power to the unit. That is, unplug the unit, press in the reset button, apply power an hold in the reset button for approximately
15 seconds.
I don't really know if that will work for this particular unit.
look for a user manual online?
Mine is mounted high in my stairwell and is not easy to access, but I can't see a reset button on it.
So -- chunk the unit?
Are you accessing the unit with the SNMP manager or the USB manager?
I know the SNMP manager requires the password but I'm not sure the USB manager does. It might be the solution.
(I'd try that, but it would be way too much trouble to dismount my unit and access it with a USB connection).
Anybody know the pass word for Netgear ME 102 Access Point Management Utility?
thanks Jesper
how do I perform a hard reset?
/Jesper
The problem is that I can't find a reset button on my device??!! So?
/Jesper
I have been looking in the online manual in the first time, but couldn't find a pass word there.
/Jesper
I'm trying to access it with the SNMP mangager and here I need the pass word. I haven't tried with the the USB manager, but eventually I will.
/Jesper
I believe the default SNMP password is "private".
Thanks Steve - the pass word IS "private"
/Jesper
