WAP with DHCP Pass Through...
Jul 01, 2006 4 Replies
Jump to replies (4)
I am looking for a good WAP or set of WAPs that i can use as a base and repeater......
The problem is that the netgear that i have supports DHCP from itself as a server but i have a windows 2003 server that i want to hand out the addresses for my wireless clients. It wont pass an address through the WAP to my wireless clients.
This is very frustrating. I know most of you will say to have a small scope in the WAP and exlude that from my win2k3 DHCP scope but i would like everything to be managed via the windows 2003 DHCP server.
I dont want to drop 600 bucks on a cisco 1200 series unit just to provide wireless access to to my laptop while im at home :)
Anyone have a good solid solution for a WAP that will do this?
A linksys wrt54gl running openwrt will do this. I have an older unit running as a pure ethernet bridge. Works just fine.
-wolfgang
On 1 Jul 2006 09:22:05 -0700, "scale" wrote in :
A wireless access point shouldn't have a DHCP server -- are you actually thinking of a wireless router? If so, then configure it as an wireless access point, as described in the How To wiki below. An access point is a network bridge, and will pass DHCP traffic back and forth.
On 1 Jul 2006 09:22:05 -0700, "scale" wrote: : I am looking for a good WAP or set of WAPs that i can use as a base and : repeater...... : : The problem is that the netgear that i have supports DHCP from itself : as a server but i have a windows 2003 server that i want to hand out : the addresses for my wireless clients. It wont pass an address through : the WAP to my wireless clients. : : This is very frustrating. I know most of you will say to have a small : scope in the WAP and exlude that from my win2k3 DHCP scope but i would : like everything to be managed via the windows 2003 DHCP server. : : I dont want to drop 600 bucks on a cisco 1200 series unit just to : provide wireless access to to my laptop while im at home :) : : Anyone have a good solid solution for a WAP that will do this?
I used to do that with a very early WRT54G running in access point mode, and I do it now with a Netgear WG302. I don't see why any access point wouldn't work as well.
OTOH, if your access point is actually a router, it might not work if you put the 2003 server on the router's WAN side. But if you put it on the LAN side, I'd expect it to work. I guess we need more details about your network topology.
