Minimum System Requirements
Nov 03, 2004 2 Replies
I am looking to put an old Pentium MMX, Win 98SE desktop in my daughter's room with a wireless PCI adapter to connect to the home network. Is there a minimum system requiremement for wireless? It works well enough on a wired network.
Thanks,
Ian
If the wireless adapter you purchase says its supports win98, you should be ok. . A lot of cards you buy have outdated drivers so check the manufactures web site for the latest updates.
Ian,
I put a Netgear PCI adapter card in my daughter's Gateway 300mhz PC with Win98 First Edition. It works great with my Linksys wireless router. It even handles WEP encryption with no problem.
Scott
Ian wrote:
