Linksys WAP54G - Only allowing one PC at a time - help!
Dec 25, 2006 3 Replies
Jump to replies (3)
I'm at my relatives for the Holiday's and they were not able to get their wireless setup. I've gone through the not-so-extensive setup CD that comes with the access point to setup a PC. What happens however, is once I am connected to the access point, it is acting as if I am directly connected to the cable modem.
My gateway is NOT 192.168.1.1 as I have set it up initially. The gateway I am seeing is the one I have if I connect the cable modem directly to the PC.
I've renamed the network as I found there was another neighbor with the same network name. I've tried enabling and not enabling WEP to see if that would make a difference but as I expected it did not.
I've reset the access point and am able to connect all the PCs in the house, but only one at a time...
Has anyone else seen this before? Any ideas on how I might fix this one?
Thanks in advance and happy holidays,
-Nate
I'm no expert, but it seems to me you need a router to provide DHCP
Yout need a wireless router not a wireless access point. you can either go buy a wired router and plug the cable modem into the WAN port of it and the WAP into one of the LAN ports or just buy a wireless router altogether All the WAP is doing is bridging you to the cable modem which is supposed to only supply one IP address. A router will take the one address from the modem and using NAT (network address translation) allow many people to use the internet at the same time.
Adair
