How can I receive the free wireless Hotspot signal then share in my own house??
Jun 29, 2007 2 Replies
Si Ballenger
You probably could try using windows ICS on the receiving computer, and then network your computers thru it. How will it work? Well, you generally get what you pay for. ;)
Can I receive the free wireless signal from wireless hotspot also share in my house?? If I can, how will it work??
Thank you for great help..
You would use a bridge, then connect the bridge to a router LAN port (wired or wireless)
