Have to keep restarting cable modem,: What does this mean?
Nov 10, 2004 4 Replies
Most relevant reply
Yves Konigshofer
What kind of cable modem do you have and who is your provider? Comcast initially supplied me with a Motorola Surfboard and it kept losing its connection to the internet. I think (but am not sure) that this had to do with its algorithm of sequentially checking a series of…
Have to keep restarting cable modem,: What does this mean? open original image
I am having a problem with my wireless internet connection. It will be working fine and then every so often I will not be able to connect to the internet. During this time, I am still able to share files, print, etc. through my wirelss network. However, I have no internet. I have been able to get it going again after restarting my cable modem by turning it off and then on again. Can somebody tell me what this means? Is the problem with the cable modem, my router, or with my DSL line/service? Mey setup is as follows: I have a cable/dsl modem connected to my DSL line in my wall. Then I have a D-link wireless router connected to the modem. I have 2 computers connected via wireless and one with a cable. All of them lost the internet connection when I have this trouble. Thanks for the help!
Harold
What kind of cable modem do you have and who is your provider? Comcast initially supplied me with a Motorola Surfboard and it kept losing its connection to the internet. I think (but am not sure) that this had to do with its algorithm of sequentially checking a series of additional channels if it got disconnected for even a moment. This process would then take 20 minutes or so before it came back to the original channel that Comcast uses. Turning the modem on and off restored the connection to the internet almost immediately,
The solution was to replace the modem with a different make and model (after the techs came twice to check the connections, etc.; btw: the modem's diagnostics reported that everything was fine with the modem). Everything has worked great since.
-Yves
I used to have this problem with my cable provider (I used their provided modem) and I had to turn it off and on several times because it stopped working. I bought a linksys cable modem it hasnt hickuped once.
Have you looked at the logs on the cable modem? Which one is it? Most are reachable at http://192.168.100.1/Some have hidden submenus like http://192.168.100.1/moreinfo.html I suffered with a bad connection in the cable that caused hundreds of "T3 timeout" errors, until one of the many techs realized that there was a grounding block and connection on the roof. They had already replaced several other connectors.
It is possible that your DSL provider needs to see the MAC address of the original computer when the modem connects. Check with your DSL help desk, or with your DSL provider forum at
. If so, you should clone the required MAC address in the router so the DSL system sees that address when the router boots.
Q
