File Sharing Issue
Jan 06, 2006 7 Replies
Jump to replies (7)
Desktop PC is conencted via Ethernet to netgear Wireless Router which in turn is connected to Motorola SurfBoard SB5200 for Internet access. 2 Laptops connect to Netgear router with wireless cards.
Desktop PC is running McAfee Firewall, has XP's built-in firewall disabled.
We ran File Sharing wizard on desktop PC, & on both laptops and shared the folders we wanted visible. The Desktop PC sees the laptops but the Laptops do not see the resources on the desktop PC.
Workgroup has the same name on all 3 machines and each machine is pingable from one another but desktop does not show up in Network Neighborhood on either Laptop.
Tried disabling all software firewalls and no joy, any ideas?
Forgot to mention, all 3 machines are running Windows XP Professional SP2.
You should do this on a wire connection and see if the machines have no problems before you go to wireless, one doesn't use some kind of File Sharing Wizard. If you say this is XP Pro, then you should disabled Simple File Sharing and then you can go to the folder you want to share with Explorer and select Sharing and do it manually. Hopefully, you are using NTFS and are able to use Authenticated User Group on shares and are taking other security measures at the machine level for the machines on your wireless network, because your network using WEP can be attacked easily and machines accessed since you're wanting to do resource sharing between machines, even with a PFW enabled.
Duane :)
Make sure the workgroup is the same on all systems ?
A common workgroup name is NOT a barrier to file sharing, it just organises people into the same group view.
Try accessing the machine via IP address i.e. start run \\\\ip address
David.
Yep checked that and it IS the same.
Cannot access it via \\\\"IP Address" BUT all 3 machiens ARE pingable from one another
Then it sounds more like a firewall issue.
