Edge-Core VG007 Wireless Client Problem
Sep 17, 2007 0 Replies
Hi again.
I have a problem that i am having trouble working out, maybe someone here has had similar problems.
I have a network setup at work with the following configeration
Wireless AP (Proxim 4000) that allows connection to DHCP SERVER to get IP ADDRESS.
IP of Proxim: 10.219.136.23 Subnet Mask: 255.255.254.0
I am trying to setup a machine on the shop floor that is running Win XP Sp2 behind an Edge-Core VG007 Pocket VOIP box 'Edge-corE : Voice & IP Telephony Product-VG007 / Wireless Personal VoIP Gateway'
which should be able to setup as a wireless client. The problem i have is the machine plugged in on the Lan port cannot connect to our DHCP SERVER.
This is totally nuts i can not figure it out
Regards
Steve
