DLink DWL-2000AP+
May 13, 2006 2 Replies
Hi
I have just bought the above unit.
The problems I am getting is that I cannot connect to the internal web server to configure it.
The unit has a IP address of 192.168.0.50 and I have set mine at
192.168.0.51, I can ping it, I can log on to it wirelessly and get an IP address.
Does anyone have any suggestions?
Is this because I am not using another DLink product to configure it?
Thanks
I have a DCS-900W. Out of the box, I had to use the CAT5 lan connection and use the provided set up software to change its IP address.
