pix 501 with dsl
Jun 06, 2006 8 Replies
Jump to replies (8)
pix 501 with dsl open original image
Hello I am hoping that someone can help me a little. I know this may be a tall order but here goes. I have new cisco 501 pix that I bought to learn with. I want to use it with my home dsl for a while. I have dsl with a modem in bridge mode. I have accessed the cisco via the pdm software and console. I setup the cisco with pppoe and successfully obtained a wan ip on the pix unit. I also have dhcp setup and my pcs are getting an inside address and dns from the pix unit. For some reason I still cannot ping past the pix unit. I know that some packets are getting out because when I ping a dns name it will resolve but no packets are returned. I was hoping to get a little guidance on this. Thanks
Can you post your config?
Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inbound permit icmp any any access-list inbound permit tcp any any access-list inbound permit udp any any pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.1.0 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 10 interface nat (inside) 1 192.168.1.0 255.255.255.0 0 0 nat (inside) 10 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.255 inside telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group pppoe_group request dialout pppoe vpdn group pppoe_group localname snipped-for-privacy@bellsouth.net vpdn group pppoe_group ppp authentication pap vpdn username snipped-for-privacy@bellsouth.net password ********* dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:27f572c9e1a3d52a63a4495cc06efb20 : end [OK]
J>> I am hoping that someone can help me a little.
Actually,I have it working with the config I posted below. Now I have two questions. I need to forward a specific port to 192.168.1.23. How do I do that and please look at this config and let me know if it is setup correctly.
Thanks in advance!
Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com clock timezone CST -6 clock summer-time CDT recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inbound permit icmp any any access-list inbound permit tcp any any access-list inbound permit udp any any pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.1.0 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.255 inside telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group pppoe_group request dialout pppoe vpdn group pppoe_group localname snipped-for-privacy@bellsouth.net vpdn group pppoe_group ppp authentication pap vpdn username snipped-for-privacy@bellsouth.net password ********* dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:a21f2686e052f39ca457363bbb7c41f0 : end [OK]
Two methods are explained here:
. I use the first method. Others have posted configs using the second. I'm not sure if one is better than the other.
I am on the net! Now I need to forward http to 192.168.1.200 I have dyndns setup so I am good on that. Here is what I changed but it is not working
access-list inbound permit icmp any any acess-list inbound permit tcp any any eq www access-group inbound in interface outside static (inside,outside) tcp interface www 192.168.1.200 www netmask
255.255.255.255
This is not working..below is current config Any help is greatly appreciated!
Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com clock timezone CST -6 clock summer-time CDT recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inbound permit icmp any any access-list inbound permit tcp any any eq www pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.1.0 255.255.255.255 inside pdm location 192.168.1.200 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface www 192.168.1.200 www netmask
255.255.255.255 0 0 access-group inbound in interface outside timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group pppoe_group request dialout pppoe vpdn group pppoe_group localname snipped-for-privacy@bellsouth.net vpdn group pppoe_group ppp authentication pap vpdn username snipped-for-privacy@bellsouth.net password ********* dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:6c9e44ce1aa80ad14ce7eb0e02fb3a51 : end [OK]
J>> Actually,I have it working with the config I posted below. Now I have
I am not very familiar with that syntax. However, I don't see your public IP address. You need to replace "tcp interface" with the public IP assigned to you by your ISP.
A simpler approach might be similar to the below:
static (inside,outside) a.b.c.d w.x.y.z
conduit permit tcp host a.b.c.d eq www any
Replace abcd with public IP and replace wxyz with LAN IP.
Hmmmm... That I don't know. Hopefully, one of the super posters in this group can tell you.
