D Link DWL 120
Aug 22, 2005 1 Replies
Trying to get this to connect to my DI 614 + with no luck. My main box is running XP SP1 wired directly to the 614+, no problem.... my daughter's laptop (XP SP1) uses the DWL 120 no problem.... I'm trying to use another computer (XP SP 2 ) with a DWL 120 and I keep getting an unplugged error... I have tried all the suggestions on the dlink site for using XP 2 with no luck.. I have turned the XP Firewall off in the Security center with no luck as well... any suggestions?
Disable the win xp wireless and use the software that came with the card only. That goes for all windows xp sp 1 or 2. make sure you have use the correct security codes as you used for the other 2 devices.
