Apple changed their documentation at my request but it proves they don't care about privacy
Sep 03, 2026 Last reply: 1 month ago 113 Replies
Jump to replies (113)
This is an update to the WPS scripts that I posted a few months ago.
Those scripts proved I could collect a list of every single access point in Apple's database, just as researchers Eric Rye and Dave Levin did, using a simple perl script which proved the results of their paper, and which went further to prove that my own hidden-broadcast SSIDs were in that database.
I complained to my next-door neighbor, who is a top-level exec at Apple Maps, where he (to his credit) pushed this wording through, but it proves, yet again, beyond any semblance of doubt, that Apple doesn't care about our privacy.
Even Google doesn't stoop this low. And that's saying something.
"The owner of a Wi-Fi access point can opt it out of Apple's Location Services by changing the access point's SSID (name) to end with _nomap.
For example, ´Access_Point¡ would be changed to ´Access_Point_nomap¡. This prevents devices from sending the access pointÿs location to Apple to include in Appleÿs crowd-sourced location database.
This opt-out doesnÿt work for hidden networks because they make their network name only available to known devices, so other devices can't detect _nomap."
This last sentence is a bold lie, by the way, since they can certainly detect it, given the field has a null value. But they lie about that too.
Below is code reproducing my tests... from which the claims are made.
@echo off setlocal EnableDelayedExpansion :: C:\app\os\python\apple_bssid_locator\bssid.bat :: Use: bssid.bat <Enter> (then enter desired BSSID to look up) :: Sample values: :: 00:18:f8:c1:4a:65 :: 00:07:89:d7:82:e8 :: 04:09:A5:3B:34:67 :: :: Logs up to 400 BSSID:GPS pairs from Apple's WPS public database :: Loop until user types q :: :: Changelog: :: v1p0 20251205 - Query Apple's highly insecure WPS database :: v1p1 20251214 - Saves to time-date stamped results.txt log file :: v1p2 20251215 - Timestamp results.txt so it's not overwritten :: v1p3 20251219 - Limit the human-readable GPS to 6 decimal places :: v1p4 20251219 - Show original raw integers + converted decimals :: v1p5 20251219 - Tried to accomodate Google Maps query to new format :: v1p6 20251219 - Changed to block-aware parsing with debug output :: v1p7 20251219 - Enable delayed expansion to fix parsing inside loops set LOGDIR=%~dp0log if not exist "%LOGDIR%" mkdir "%LOGDIR%" :: Create a unique session log (YYYYMMDD_HHMMSS) for /f %%A in ('wmic os get localdatetime ^| find "."') do set dt0=%%A set "session_ts=%dt0:~0,8%_%dt0:~8,6%" set "session_log=%LOGDIR%\session_%session_ts%.log" echo === New BSSID lookup session started at %date% %time% === >> "%session_log%" echo. echo === Nearby Wi-Fi Networks === netsh wlan show networks mode=bssid echo ============================= :loop echo. set /p BSSID=Enter the BSSID (or q to quit): if /I "%BSSID%"=="q" goto end :: --- Clean up input --- set "BSSID=%BSSID:"=%" set "BSSID=%BSSID: =%" :: --- Make filename-safe version --- set "safeBSSID=%BSSID::=-%" :: --- Generate timestamp for THIS lookup --- for /f %%A in ('wmic os get localdatetime ^| find "."') do set dt=%%A set "ts=%dt:~0,8%_%dt:~8,6%" :: --- Timestamped output file --- set "outfile=%LOGDIR%\bssid_%safeBSSID%_%ts%.txt" :: --- Clear previous coordinates --- set "LAT=" set "LON=" echo === Lookup started at %date% %time% === > "%outfile%" echo BSSID: %BSSID% >> "%outfile%" echo. >> "%outfile%" :: --- Run Python lookup --- python.exe apple_bssid_locator.py %BSSID% --all >> "%outfile%" :: --- Display results --- echo ----------------------------------------------- type "%outfile%" echo ----------------------------------------------- :: --- Block-aware parsing of coordinates (with delayed expansion) --- set "CAPTURE=" set "LAT=" set "LON=" for /f "usebackq delims=" %%L in ("%outfile%") do ( if /i "%%L"=="BSSID: %BSSID%" ( set "CAPTURE=1" set "LAT=" set "LON=" echo [DEBUG] Found block start for %BSSID% ) else if defined CAPTURE ( echo [DEBUG] Line in block: %%L echo %%L | findstr /i /c:"Latitude (degrees):" >nul if not errorlevel 1 ( for /f "tokens=2 delims=:" %%A in ("%%L") do set "LAT=%%A" if defined LAT set "LAT=!LAT: =!" echo [DEBUG] Parsed LAT candidate = "!LAT!" ) echo %%L | findstr /i /c:"Longitude (degrees):" >nul if not errorlevel 1 ( for /f "tokens=2 delims=:" %%B in ("%%L") do set "LON=%%B" if defined LON set "LON=!LON: =!" echo [DEBUG] Parsed LON candidate = "!LON!" ) if defined LAT if defined LON ( goto :gotCoords ) echo %%L | findstr /i /c:"BSSID:" >nul if not errorlevel 1 ( set "CAPTURE=" ) ) ) :gotCoords echo [DEBUG] Final LAT = "!LAT!" echo [DEBUG] Final LON = "!LON!" :: --- Validate parsed coordinates --- if not defined LAT echo [DEBUG][ERROR] Latitude not captured. Check Python output format near "BSSID: %BSSID%". if not defined LON echo [DEBUG][ERROR] Longitude not captured. Check Python output format near "BSSID: %BSSID%". :: --- Save results --- echo === Lookup finished at %date% %time% === >> "%outfile%" echo. >> "%outfile%" :: --- Append to session log --- echo [%date% %time%] BSSID: %BSSID% >> "%session_log%" echo Latitude: !LAT! >> "%session_log%" echo Longitude: !LON! >> "%session_log%" echo. >> "%session_log%" :: --- Append to master log --- echo [%date% %time%] BSSID: %BSSID% >> "%LOGDIR%\results.log" echo Latitude: !LAT! >> "%LOGDIR%\results.log" echo Longitude: !LON! >> "%LOGDIR%\results.log" echo. >> "%LOGDIR%\results.log" :: --- Open in Google Maps --- if defined LAT if defined LON start msedge "
!" goto loop :end echo Exiting. Goodbye! endlocal :: end of C:\app\os\python\apple_bssid_locator\bssid.bat
I don’t understand what you’re complaining about, exactly. Your wi-fi network broadcasts its existence to all and sundry, and yet you feel upset when somebody collects that information and passes it on.
And hiding SSIDs is a complete waste of time, which gains you nothing in security or privacy. Don’t do it.
Hi Lawrence,
I respect you, but I have to teach you so that you learn what you do not know, as you don't even know that you don't know what you said is wrong.
Rest assured, I know what I'm talking about. :)
I've discussed this issue with Brian Krebs and Daniel Veditz (of the Mozilla Security Team) so it's quite well understood by professionals.
The problem is most people who are NOT Wi-Fi pros, are stuck in the stone age when it comes to thinking about what a hidden broadcast actually does.
Worse, I've had to have this discussion a billion times because almost nobody else in the world outside of tech people knows anything about it.
The facts is you're thinking about security. Not about privacy. They're not even close to the same thing.
This is about privacy. Not security.
Apple literally manually removed my SSIDs from their database, as a result of my RADAR bug report and Apple literally changed their documentation.
That's new. That's solely because of me.
As I had reported months ago, Apple at first pulled the stalling legal trick of saying it's "not reproducible" but the person I had submit that RADAR bug report is an executive in the Apple Maps division who happens to be my next-door neighbor, and he knows full well I know my stuff.
They eventually told me "don't use a hidden SSID", which is the wrong answer, and they KNOW it's the wrong answer because they literally manually removed my hidden SSID (but only mine!) from their public WPS database.
The entire reason for a hidden SSID is privacy. If the SSID is hidden, it tells everyone you want to be private a. Google respects that b. Mozilla respects that c. Everyone respects that d. Except Apple
There's a HUGE difference in what happens to privacy between these events: A. You set the SSID to null B. You append _nomap to your SSID
Of the million things people need to know about privacy, most know 3.
That’s their problem, though. Trying to offer some kind of sop to their ignorance is not actually making them safer.
This is about the *perception* of privacy. Like telling people they don’t have to worry about closing their curtains, they just need to close their eyes -- if they can’t see the people outside looking in, then those looking in can’t see them!
“Tells everyone” ... privacy is supposed to be something where you don’t “tell everyone”!
Your car broadcasts its license plate number to anyone in sight of it, yet people are rightfully ticked off at Flock cameras everywhere recording them.
Paul Rubi:
Because machine data acquirement is more powerful.
() ascii ribbon campaign -- against html e-mail /\ www.asciiribbon.org -- against proprietary attachments
I guess it is because the SSID is terminated in _nomap, which is documented as a flag to Apple and others to not store this SSID in their maps. But Apple is/was mapping them all the same.
Yep.
I got the impression they were claiming that their SSID was hidden, which makes it irrelevant as to whether it has "_nomap" at the end of it, but that Apple had somehow discovered and logged it nonetheless. It seems highly implausible.
Perhaps unless an Apple device was used to connect to it?
I was wondering how you got on with your "experiment" only the other day.
You said you had installed two routers in friends' houses downtown, move them around and then track the movement in the database.
I'd like to see the results. How often did you move them, how far, and were the details tracked in the "apple database"?
Hi Lawrence,
I say with all respect that your statement is too wrong to accept as is. What you just said, I've heard a thousand times before, from many people.
And yet, it's no different than what I've heard by asking the guy next to me at the gas pump since the 1960's why he puts premium in a Honda Civic.
For over five decades, people have been parroting what someone told them. None of them actually understand a word that they're obviously parroting.
Same here...
Again, I respect you for your technical acumen which is greater'n mine. But I can't tell if you know privacy differences between these situations: a. iPhone owner happens to walk by my house b. Android owner happens to walk by my house
Do you know the difference in terms of what happens, or not, with respect to my unique AP BSSID & GPS location (both of which are exactly my house)?
I do. A. So does Apple. B. So does Mozilla. And Google.
Mozilla respects a hidden access point broadcast (i.e., it's set to null). So does Google (surprisingly). i. But not Apple. ii. And yet, Apple loudly & vociferously proclaims to care about privacy.
That's the part that is the most hurtful. Apple brazenly lies, with a huge "what me?" seemingly innocent smile.
Yet, Apple immediately removed my BSSID/GPS from their WPS database. Because they know what I know about the lack of privacy in that regard.
It may well be I'm the only one in the world who is honored so by Apple. But that's not my point as I care about everyone's privacy. Not just mine.
Another question for you, Lawrence, again, because I respect your acumen.
Do you know the difference between these two situations: a. iPhone owner happens to walk by my house & it uploads my BSSID/GPS? b. Android owner happens to walk by my house & it uploads my BSSID/GPS?
What happens then? Do you know?
I do. Anyone who can't answer those queries, can't possibly understand the issue.
Privacy is a million things, of which most people only understand about 3.
Do you have any intention of letting anyone else know what the issue is?
This part of the discussion contains 3 very well thought out reflections.
  1. Carlos
  2. John Ribbens
  3. Nuno Silva
Months ago, we wrote a python script that essentially gathered the physical location of every single unique access point BSSID in the world (see sig).
All we did was exactly reproduce the results from Levin & Rye in this paper
*Surveilling the Masses with Wi-Fi-Based Positioning Systems*
There were "posters" who disputed this, particularly on the Apple ngs, but it was clear they were denying only to defend the honor of their God.
They didn't understand a single thing, which is telling when someone denies research papers that no professional would deny, yet Apple posters deny it.
We were able to effectively pick any area of the world that has had an Apple mobile device swing by at some point in time and then we could locate every single BSSID/GPS location in that area, to identify, for non-apartment-style areas the home address, and then, if that router was moved to a new location, instantly, we could locate where they moved it to.
This is in keeping with what the paper claimed, and for Apple posters to deny it (which they did), is not only absurd, but telling in how desperate Apple posters tend to be when it comes to defending their religious God.
To remove doubt, Carlos is correct in his statement above, that every access point I discussed with Apple Maps executives ended with "_nomap".
Therefore, they are not "supposed" to be in the Apple world wide WPS db. And yet, they were.
None of the Apple documentation at that time said that they would be.
Only because of me (and I know this from my emails with Apple), is the cite which I provided saying that even with _nomap, you're still in their db.
Which means, if I didn't have Apple remove it manually (which they did at my insistence), then anyone could instantly track me down to the meter. were I to move my router to another location in the world (by my BSSID).
Apple knows this. They're not stupid.
They're liars. But they're not stupid.
Notice that what Jon Ribbens said is also true, and more telling than what Carlos had mentioned, although both are perfectly accurate assessments. a. The SSID has _nomap b. The SSID broadcast is hidden c. Google refuses to put that in their public WPS database d. Better yet, Google has protections on their public WPS database e. SO does Mozilla (although their database has been deprecated) f. So does everyone... g. Except Apple
Worse, Eric Rye and Dave Levin proved that once the unique BSSID is in the Apple WPS database, anyone in the entire world can track that router, down to the meter, no matter where it is subsequently moved to (and no matter what any subsequent SSID may be), which I also proved in my scripting.
Given Apple posters will stop at nothing to defend their religious God, we wasted umpteen posts proving that, but not one of them ever ran the code.
I did. I simply ran the same python code that was described in the research. And got the same results (I stopped at a fefw hundred thousand, while they went on to gather billions, or at least hundreds of millions, as I recall).
Proof of concept is all I needed to affirm that if I happen to know the BSSID of someone's router (oh, say, an ex wife or a disgruntled employer), I could track that router anywhere in the world, easily, down to the meter.
As for what Nuno Silva said, all we need to do to get our unique BSSID and GPS location into the Apple WPS database, is for an Apple mobile device to be within hearing distance, for only a moment or so, whether or not we have told Apple by the SSID postfix of _nomap, if the broadcast is set to null.
Those who actually understood what I wrote above, which is likely only about one one-hundredth of the people reading this (simply because they have bias that they can't shake), will understand the catch-22 involved.
For data collection... A. Google/Mozilla do privacy one way (i.e, the well-known correct way) B. Apple does it completely differently.
Worse (far worse), for data distribution... A. Google/Mozilla do privacy one way (i.e, with judicious controls) B. Apple does it completely differently (i.e., no controls at all!)
Think about that.
Hi Jon,
Lil' ole' me can easily track a BSSID anywhere in the world, down to a meter or so accuracy, if I want to under the common circumstances which I've outlined in this thread (and in others).
I move my router around a lot, and I don't want just anyone being able to track all my movements down to a meter accuracy when I do that. Do you?
You were correct in your prior post to Carlos, when you said (verbatim): "I got the impression they were claiming that their SSID was hidden, which makes it irrelevant as to whether it has "_nomap" at the end of it, but that Apple had somehow discovered and logged it nonetheless. It seems highly implausible."
But, of course, there's more detail (which I provided in my responses).
I explained it in gory detail, and even provided a link to the research. I provided some of the python scripts too (although they're not the point).
We've discussed this ad infinitum on the Apple & Android & Windows ngs in the past, although I don't remember how much we brought in Python folks.
What's *new* is Apple told me in my email that there was no way to have WPS privacy from Google/Mozilla if I wished to have WPS privacy from Apple.
It's a catch-22 situation. Which would you pick?
HINT: If we read the research paper, it's a no brainer which one to pick.
Of the million things to be considered for privacy, most people know 3.
Hi Chris,
Thanks for remembering that I ran a 3-router experiment early in the year.
That experiment was run in the first month of the year, which was before Apple changed their documentation saying that they will track us forever.
Those BSSIDs are now in Apple's WPS database, so the experiment worked. Now, anywhere in the world I move those routers, anyone can track them.
Instantly. Down to a meter or so resolution. With no controls whatsoever.
Think about that. What if I were hiding from an ex-wife or disgruntled Apple poster?
Anyone on the planet can track my router location from anywhere in the world down to meter-like accuracy, and I simply cannot stop them.
The only thing I can do, once my BSSID is in Apple's WPS database, is throw that router over the next bridge because I can't change the BSSID on it.
I can be tracked forever, if my location is associated with that router.
Just like the research paper said it would be. I simply reproduced exactly what the research paper said was possible.
Worse, I proved hiding the BSSID broadcast was a catch-22 situation. a. It kept the BSSID out of Google/Mozilla hands (they're well behaved) b. Yet, it's permanently in the Apple WPS database
Which do you pick to be in, given you can't solve both issues at once?
HINT: Apple's WPS database has no protection whatsoever, as proved by: *Surveilling the Masses with Wi-Fi-Based Positioning Systems*
My research *started* with that paper, and took it to the next level.
Of the million things to know about privacy, most people only know 3.
Heh heh heh...
While I realize Apple religious zealots will attack people personally because they defend the mothership to the death, no matter what, without ever even understand the issue at hand, what matters for this thread, is we discussed this at length on Apple ngs using the *old* Apple documentation.
We reproduced the work of researchers from Levin & Rye in this paper *Surveilling the Masses with Wi-Fi-Based Positioning Systems*
We posted the python scripts. And we chose a location in Louisiana to track router movements by BSSID. And we listed the results, by BSSID, GPS and home address. We quite easily found the registered owners of each of those residences.
Do you remember that? I do.
We proved that everything said in the paper above was correct, down to the very fact that Apple let lil'ole'me collect tens of thousands of identifying pairs of BSSID's and GPS locations (which map to addresses).
We proved, even at that time, months ago, that anyone could track the movements of that BSSID forever, from anywhere in the world, to anywhere else in the world, without any protection whatsoever by Apple.
This is what the paper said would be the case. And it was.
What's *different* is the paper did not cover hidden broadcast BSSIDs. I did.
That's the test which Chris is talking about, and which Apple knows about. a. Apple _removed_ my BSSIDs _after_ I told them about this. b. And Apple _changed_ the documentation, _after_ I told them about this.
That's pretty good for someone whom the Apple trolls claims "knows NOTHING about Apple", especially since I proved every single claim that I had made.
Of the million things we need to know about privacy, most people know 3.
The flock camera analogy only works if anyone in the world can access it. *Surveilling the Masses with Wi-Fi-Based Positioning Systems*
While I understand the analogies being presented, and certainly I understand the purpose is to claim "no big deal" as a result, I must beg to differ because the analogies, while reasonable, fall flat on some regards.
What if, for example, the government allowed you to put a black cloth over your license plate, and that is a clear indication that you don't want it to be recorded by Flock cameras (& by extension, your movements recorded).
What if Google cameras respected that black cloth as did Mozilla cameras. But what if Apple cameras refused to respect that common leave-me-alone black cloth?
Think about that. What if *only* Apple cameras lifted up that black cloth, on purpose. So that they could get your unique vehicle VIN that tracks you everywhere.
Pretty bad, huh? But wait... it gets worse.
What if the Google camera, if it happens to get your license plate, which is tied to your unique VIN, but the Google camera sees *another* indicator that you do not want them to put that license plate into their database.
Let's say that's a sticker, on the plate, that says, oh, let's say _nomap.
What does Apple do? Versus what Google and Mozilla do?
But wait, if that's not bad enough, there's still more. A lot more in fact.
What if anyone in the world could look up that license plate & related VIN from anywhere in the world, and there are absolutely no controls on that?
What?
Do you see the difference?
Allow me to provide an example: a. Let's say my ex-wife is in Germany, back in the home country b. But, she wants to track my vehicle everywhere I go c. As described in the aforementioned research paper, she can.
It's no different than you choosing the license plate of your ex-wife (or whomever) and tracking them anywhere in the world, with no controls on that.
Do you see why understanding the problem set makes the flock camera issue only superficially an analogy.
The flock camera could only be an analogy if anyone in the world could track your movements down to a meter resolution, with no controls on that.
What people need to know about privacy is complex, so they simplify it.
Ok. I think BSSID means "MAC address of the WiFi access point". I don't know what circumstances you can track them, and you don't seem to have said in this thread.
I suppose if someone had reason to target me specifically, and they had a real-time way of tracking BSSIDs, and for some reason I can't imagine I was taking a WiFi access point with me, I... oh, wait. In that circumstance I would not take a WiFi access point with me, for the same reason I wouldn't have my mobile phone radio enabled, or would not have a mobile phone with me at all, depending on the threat model.
I saw no response from you to that post. But from what you're saying in the post I'm replying to now, I wasn't correct - I now think you're saying that Apple store the BSSIDs of access points of WiFi networks with hidden SSIDs, because they *don't* know the SSID and therefore can't tell if it has "_nomap" appended, and so don't exclude it.
I'm not sure what I think about that, and I don't know what any of the other companies that map SSIDs do in the same situation. I'm not sure why Apple would store location data of BSSIDs with no visible SSID - it doesn't seem like it would help the geolocation feature much, since hiding the SSID is pretty rare.
You haven't done any of that in this thread so far as I can see.
Sorry, what does WPS have to do with it? And why is it a binary option? A non-hidden SSID with "_nomap" would presumably provide privacy from all those companies? Or do some of them not support that? Or is having a non-hidden SSID not acceptable to you? If so, what are the options for privacy you are referring to?
I mean I literally do pick a non-hidden SSID without "_nomap" on it, that I've kept constant for decades. I've never even seen a SSID with "_nomap" on it. There is no-one I regard as a threat, let alone someone who would be a threat and who would know my SSID let alone my BSSIDs.
What research paper?
Maria Sophia snipped-for-privacy@comprehension.com writes: [...]
[SNIP]
Can you please restrict this to newsgroups where it's relevant?
In particularly, there's in this thread nothing about Python or Windows 10.
Keith Thompson (The_Other_Keith) Keith.S.Thompson+u@gmail.com void Void(void) { Void(); } /* The recursive call of the void */
