Agent 3.2: Can I change the <From> field?
Jan 31, 2006 4 Replies
John Navas
[POSTED TO - REPLY ON USENET PLEASE] 1. Specify whatever email address you want in your configuration. 2. Use your Gmail address (and password) for SSL. 3. Add the email address you are specifying to your Gmail account.
I appreciate being able to use the Gmail authenticated SMTP server, which requires SSL, but now my email messages reflect the Gmail account in the field. Yes, I can set the field, but I don't want folks to think that the Gmail account is now my "real" email address.
Is there a way to set the field to something other than the account used to authenticate to the SMTP server?
Thanks.
Oops. I posted this to the wrong group, but you STILL had the answer to my question.
BTW, there is one other step. I needed to make my "real" email address the default address on that Gmail account.
Thanks!
It does not need to be the default.
You're right yet again. I would never have guessed that simply having my real email address in the list of addresses in the Gamil account would allow it to automatically use it in the From: field.
