NEWS: Public Wi-Fi even more insecure than previously thought!
Aug 14, 2007 1 Replies
NEWS: Public Wi-Fi even more insecure than previously thought! open original image
[see IMPORTANT NOTES below]
How to gain permanent access to Gmail accounts
Black Hat Users of Yahoo! Mail, MySpace and just about every Web 2.0 service take note: If you access those services using public Wi-Fi, Rob Graham can probably gain unlimited access to your account - even if you logged in using the secure sockets layer protocol.
Graham, who is CEO at Errata Security, demonstrated the hack to attendees of the Black Hat security conference in Las Vegas. The technique uses a plain-vanilla network sniffer to read the cookies returned by Google Mail, Hotmail and scores of other sites after a user has entered login credentials.
The websites rely on the cookie as a session ID to validate the browser as belonging to the person who just logged in. By copying the cookie and attaching it to a completely different browser Errata Security researchers showed it was easy to gain unfettered access to the accounts of others.
"If I sniff your Gmail connection and get all your cookies and attach them to my Gmail, I now become you, I clone you," Graham said during a presentation on Thursday. "Web 2.0 is now fundamentally broken."
The technique allowed Graham to open the Gmail account of an unsuspecting Black Hat attendee who had used the conference access point to get his email. Although the Errata Security chief closed the window several seconds after accessing it, nothing short of good manners prevented him from reading the person's messages, or, for that matter, accessing maps, calendar or other Google properties used by that person.
The hack caught our attention because it shatters a common assumption concerning secure surfing on public access points. Up until now, we felt relatively safe using hotspots to access email as long as we logged in with an SSL session. Yes, we knew that any subsequent pages that were not appended by "https" in the address bar were were susceptible to snooping, but intruders still had no way to access the account itself.
Now we know better. Any session that isn't protected from start to finish by SSL is vulnerable to the hack. And because session IDs generated by most sites are valid for an indefinite period, that means intruders could silently access our accounts for years - even if we regularly change our passwords.
The only way Graham said he knew to work around the vulnerability is to use Google and select options that automatically keep Gmail, Google Calendar and several other properties encrypted throughout the entire session. (Check our Defcon Survival Guide
for more on this.) If you use most other services, you're out of luck, as they all switch to an unencrypted browsing mode after login.
IMPOTANT NOTES:
  • Although Google Notifier uses secure HTTPS to check your mail, when double-clicked it does NOT launch secure Inbox connections! To modify it to do so, see my hack at ),
  • CustomizeGoogle is a free Firefox extension that can force secure HTTPS connections for both Gmail and Google Calendar.
  • Another way to secure Gmail is to use a POP3/SMTP client (e.g., Mozilla Thunderbird ). (Gmail POP3/SMTP only works over secure connections.)
  • Other online email services may NOT fully securable! Don't use them on public networks except over VPN.
  • Free VPN is available from AnchorFree . For other VPN options, see JiWire Hotspot Helper is recommended.
On Tue, 14 Aug 2007 15:41:18 GMT, John Navas wrote in :
Also, HTTPS can and *should* be used for iGoogle:
