10/100 and 30Mbps Internet
Jan 08, 2006 0 Replies
Hi All.
I have a 30Mbps internet connection. I connect my cable modem directly to my pc's 10/100 ethernet card and get as good as 30Mbps. So far, so good.
However, when I connect the cable modem to my D-Link DI-614+ and then run a cable from one of its 10/100 Ethernet ports to the PC's Ethernet
10/100 Ethernet card, the internet speed is halved.
I called D-Link support which I think is in India. They're advice? Turn of my microwave oven. I am not kidding.
Is it because the router is wirelessly broadcasting the signal or is it due to some limitation of the router?
Any help is much appreciated.
Neil
