Voip advice
Aug 03, 2004 1 Replies
Hello,
I own a small business, and want to connect a remote employee to my key system. I have a Nortel Compact ICS, and a spare ATA unit. The remote user will probably be connected via DSL. I'd like to do this as inexpensively as possible, so what hardware is recommended? The ATA mentioned above provides a POTS style connection to the digital key system.
TIA,
Rick
Like most things, you can do it cheap or you can do it right. The best way I've seen is to use the MCK EXTender 4000. the remote employee can then use a standard digital phone and use all the features as anyone in the office can.
