how to use 2 voip providers with a softphone?
Nov 06, 2004 2 Replies
BlueRinse
The free X-Lite SIP softphone has three lines so you would see the incoming call and could easily answer it by hitting the line button. The paid X-Pro has 9 lines.
I would use a softphone for example,
supposing that I have a +212 xxx xxx number for receive calls, I register the proxy 1 with them, and who call me at that number find me.
Now, for make calls I would use another voip plan, so if in the proxy2 I select another provider and I make a call, what happen if somebody call me to the +212 ? The softphone will ring or not becouse I'm in the second proxy plan?
do you understand? how to do it?
thanks
iaxComm seems to handle multiple simultaneous calls.
've only experienced it when logged in to the same service (mine) with two accounts but it seemed o.k.
--kyler
