Problem calling **243 from FWD - Hardware phone
Nov 05, 2004 0 Replies
I have a SPA 3000 Line 1 configured for FWD Pulver account and it works perfectly to receive and make calls to FWD numbers. I am even able to make calls to this FWD account from Vonage numbers. My problem is SPA 3000 doesn't let me dial my Vonage number
1-916-671-1306 through FWD number peering (**243 1 916 671 1306). When I try dialing **243 1 916 671 1306 from a softphone provided by FWD (pulver.communicator), it works perfectly well. Here is my current dial plan ([2-79]11|xx.|*xx.|**xx.|1[2-9]xx[2-9]xxxxxx.|xx.|xx.|*xx). I have even tried (xx.|*xx.|**xx.) nothing helps. It doesn't understand when I dial ** in front for some reason. I even tried a dialplan (xx.|xx.) and dialed #8 and
1306 but in vein. Could you please try calling my vonage number through a SPA configured with a FWD account at 1-(916) 671 1306 and let me know the config changes I would need to make. Thanks. Sekhar
In case, if you don't have a FWD account details handy: UserID : 493337 Password : 12345 Proxy : fwd.pulver.com Use Outbound Proxy : Yes Outbound Proxy : fwdnat.pulver.com:5082 If you would like to try out the softphone here is the download:
this works to dial my vonage number.
