Re: What Type of Wireless Should I Use?
Apr 30, 2006 0 Replies
> I use those RAD AirMux 200 radios for our backhaul - not bad... With
>> the right module you can even run 4x T1 lines over it for voice
>> traffic or whatever...
> Dlink and now Linksys sell APs at 802.11n that can do ~100mbps and
> theoretically 600mbps in time. Jack up the power and add directional
> antennae and I'm golden. Just thought there might be something better
> out there I haven't heard of.
I am just worried about using D-Link and Linksys gear for that type of a project ... There are three levels:
Home User Commercial Carrier
Linksys and D-Link are home user (some will likely not agree with me on that...). Can you use them? Sure! Will they work? Sure ... For a bit ...
We are an ISP and before I was hired they were using D-Link and Linksys
5-port switches and diffferent locations ... Once I installed some CISCO switches our performance went up 500%+ -- just because it states speed X does not mean it is really that fast. I checked the data sheet for the Linksys 802.11n radio -- it only has 10/100Mbps ports ... So the maximum wired-to-wireless speed would be 200Mbps (upload = 100Mbps - download = 100Mbps).
