Re: VOIP Over ADSL
Aug 28, 2005 0 Replies
What kind of equipment do I need to do sharing as well as having VOIP
> calls using regular phones.
> do I need to have purchase regular VOIP router which can also share
> connection, or do i need to have specific differnt one for ADSL.?
Any VoIP router should work, or you can buy a router and a separate VoIP adapter. Your ADSL modem should have a jack for a normal Ethernet cable to plug into your router. If it doesn't (there may still be a few that are USB only), call up the telco and tell them to switch it for one that does.
R's,
John
