adsl modem question
Aug 05, 2004 3 Replies
Jump to replies (3)
Hi there, If I want to buy a good adsl modem what do you recommend? Also If I will buy an adsl modem with a a few ethernet ports does it mean it is a modem/switch/router all in one? Thanks a lot, Calin
Try the following to cover all the bases. Has ADSL modem, router and wireless access point all in one. Make sure your ISP supports it, hough. -Dave
You need to obtain one that is compatible with your ISP.
Dave
Addendum:
This News Group is for Cable Modems.
You should have posted to; comp.dcom.xdsl Which covers ADSL
Dave
