voip over adsl?
Aug 27, 2005 1 Replies
Sekhar
Look at You may lookup for similar devices which combine "ADSL Modem + VOIP + 4 port Router" If I were you, I would go for a cheap router ()and SPA 2000. This one has a router and VOIP VOIP Modem + Router may be several such ones available in the market BUT DONT BELIEVE THEY…
hello,
i'm having 256 kbps adsl connection from dataone bsnl.
i want to setup voip phone upon it & also want to share the same connection between three pc, currently working on only one.
i'm having adsl modem installed by service providor.
what kinds of equipments do i need to do sharing as well as having voip calls using regular phones.
do i need to have purchase regular voip router which can also share connection, or do i need to have specific differnt one for ADSL.?
does it work with existing adsl modem or does i have to change it?
i'll look foreward for any reply.
thanks in advance krunal
Look at
and SPA 2000.
Just VOIP
ADSL Modem + Router
There may be several such ones available in the market BUT DONT BELIEVE THEY ARE AVAILABLE IN INDIA :(
Cheers!
Sekhar.
