parts needed
Jun 21, 2005 5 Replies
Jump to replies (5)
Anyone have access to ITI CS 4000 battery cables? Need (2) and GE - ITI says they are no longer available items.
thanks
You mean you don't have a set in that junkpile... (pardon me)... warehouse in your garage??
Try your local Radio Shack. They carry all kinds of connectors that may fit. If you can find the right plug, the rest should be easy. You may also consider replacing the connector with a matching set that does the job.
Jim Rojas
