LED's
Nov 07, 2005 3 Replies
Jump to replies (3)
Many LED's drop 1.2 volts across them so you have 12 minus 1.2 = 10.8 Volts. Assuming a current of 15 ma, you might try a 720 Ohm resistor. Not knowing the exact LED's you have, no one can say exactly. If you want to be on the safer side, start with a 1K resistor. Somewhere between 10 and 20 ma should provide sufficient brightness. Disclaimer: If you burn them up, I'm not responsible.
Bob
I have an assorted pack of led's. No numbers lots of colors. How do I tell what resister to add in the circuit at 12 DC
Here is some information that may help.
Jim Rojas
