Complicated Napco MA2600 Internals Issue
Feb 27, 2007 8 Replies
Jump to replies (8)
Complicated Napco MA2600 Internals Issue open original image
I've been reading some of the expert posts here and I know that you're the right group for this one.....
I have a Napco MA2600 system in my house and find that it generates a lot of RF noise from below 300KHz up to 2MHz. Bad enough for listening to AM radio but I recently got interested in ham radio and that makes the problem much worse. The RF noise is coming not just from the AC line but from all the contact wiring throughout the house so it's not easy to get rid of.
My solution is to shut down the alarm system completely and although this works it's a pain to bring it up and down so I've set up a system to do that remotely. The "system" is a remotely control relay that cuts off the low voltage AC into the control panel and simultaneously the 12V battery supply. The cutoff function works great! But when the system powers back up it sets off the alarm unless the AC is applied first followed by a delay of a few seconds then the 12V battery can be connected up.
I suppose the I could ehnace my relay circuit to add the needed delay, but I just assume not even bother with the 12V battery and run the system without that. Of course you can't just pull the battery on this system since the controller is busy with alternately charging and checking it all the time and if it finds it's not there it won't let you arm it. There's no detail on the charging/checking battery system in the manual. If I had a schematic I'm sure that I could figure it out but finding one seems to be an impossible task.
So I'm looking for ideas along the lines of one of these, or maybe something entirely different.
1) There's obviously an "AC power good, ready to accept 12V battery voltage" signal somewhere in the panel. If I can access that point I can use it to control the relay for the 12V battery and not use a fixed (and unreliable) time delay. Where is it? There's some mention of an optional PS3002 power supply that hooks into the control panel through lugs E7 an E18. Could one of these be the point that I'm looking for, I haven't done any circuit probing yet.
2) Faking out the battery check with a dummy battery of some sort doesn't seem to be a workable solution, since if it really thought the battery wasn't there when the AC power was applied it would set of the alarm. Turning off the battery check completely seems like it would work but I have no idea how to do this.
3) Find some magical way to eliminate the RF noise.
4) Throw the whole thing out and buy a different system.
Thanks,
Katie
It could be time for you and Paul to check out some new headphones.
The MA 2600 is a very old panel. Many early Napco panels had RF issues. Early MA-800 panels could pick up nearby AM radio stations. MA 1000 series were a pain to many HAM operators as well. Any panel with a polling loop or analog loop can generate some nasty RF in certain environments. Even if you weren't having RF issues I'd suggest upgrading from the MA 2600 since it is beyond legacy status.
I don't know how your system is programed but if it isn't programed to alert on AC fail, just get a power supply with a back up battery and power the system through the battery terminals only. No AC to the panel at all. Do you have access to the dealer programing? If you do, and the system is giving you an AC fail signal, I think you can program it to not alert to an AC power failure. I'd have to check the manual to be sure, however. Let me know if you have access.
If not, some panels can be fooled into thinking that AC is applied just by applying 12 VDC to one of the AC terminals. I don't remember if the 2600 can do this or not. You may have to follow some circuitry on the board to find out if they're using a bridge rectifier or not or which of the AC terminals to use.
Jim,
That's a great idea and I do have full access to the programming.
Thanks!!!
-Katie
Try
1 choke coil on the low voltage AC panel input
2 use .01 capacitors in parallel, on each of the alarm zone negative terminals and tie to battery ground. This will bleed off any AC from the zone cables and block the DC to battery ground. Do the same with keypad terminals. This will help nullify induced AC noise from nearby
110VAC lines and induced RF noise from flourescent lights.
This has worked for me for years. Alarm companies have sent me to their troublesome panels. However, I never did tell them what my solution was - aka guaranteed income !
gqc
Katie Wasserman wrote:
Katie,
If you can re-run your keypad cables, use shielded cable to minimize RF leakage from the databus. You may use shielded cable with Napco, Honeywell, and Bosch's data loops and keypad data cables. Consult the ARRL's RF Handbook
for more information. IMHO, you best bet is to scrap the old system and upgrade to something newer that won't generate as much RF Hash...
73, Russ/KN6SD
Russ, Thanks for the suggestion and ARRL pointer but rewiring isn't an easy option.
But I did try GQC's idea of using bypass capacitors on all the lines and that made a huge different, especially on the keypad lines, noise dropped by almost 15db. All of the noise is/was coming from the alarm wiring, running running on the battery alone gives the same noise level, so the AC line choke wasn't needed.
Jim, your idea of running off the battery power feed only doesn't work. The system needs the AC power to start up or it triggers the alarm, there seems to be no way around this. Putting in a fake battery using a capacitor discharging through a diode and charging through a parallel resistor didn't work either. The system does a 1 second test using the battery about 1 minute after AC startup, that's how it determines if the battery is good. After that point it seems to do a battery check each time the system is armed. So you really do need to have a real battery in there (or a giant capacitor) to make this alarm function.
Thanks to everyone for you help on this.
73, Kaite (k1kdx actually k1kdx/ae)
Did you try to apply 12VDC to one of the AC terminals?
I've got a few Napco and other manufacturers systems running on 12VDC only on boat alarms. Never used a 2600 for this application though. Applying 12VDC to one of the AC terminals has worked for me as far as fooling the system into thinking AC was applied. When the power is removed from these units and restored, there is no indication of AC power loss or low battery. I have no idea whether running it this way will reduce the RF emissions.
My original suggestion to you about powering the unit this way, was following up on your method of wanting to shut the system down while you were transmitting. I still didn't check the installation instructions but did you investigate whether you can program the panel to ignore an AC power loss?
Another thought occured to me also, regarding the "sequencing" of the application of AC and DC. If I remember correctly ( ie. I could be wrong) when you power up the panel, there is a momentary "blip" on the output of the siren. This might mean that the Aux relays are being momentarily "pulsed" too. You may be able to utilize this momentary closure of the Aux contacts to pic another relay that would lock in. This relays contacts hooked in series with the positive lead of the battery, could then apply the DC voltage a split second after AC is applied.
