I'm wiring my house right now and am going to buy the Omnipro II controller. What wire do I need to run between a touch screen interface or LCD console to the mechanical room where I will mount the unit?
Thanks for helping me out, Gary
I contacted HAI and they told me that I should use cat5e for anyone else who might have this question.
Read the full replyI'm wiring my house right now and am going to buy the Omnipro II controller. What wire do I need to run between a touch screen interface or LCD console to the mechanical room where I will mount the unit?
18/4 or 22/4 should be fine
Gary inspired greatness with:
Well... hmffffttt....
Maybe next time you'll just call first.
18/4 or 22/4 stranded or solid will be fine though.
The LCD pad I mounted a few months ago only required 4 cables. Maybe the newer pads are different
